Re: Ok to tap DV nipple line for boost gauge? (Nessal)
Sorry, no digital camera here. You simply use a small section of additional vacuum line you have laying around. the extra line goes on the FPR then put the "T" between the line on the FPR and the line that normally goes on the FPR. you now have the middle of the "T" for your boost line for your guage.
There is a grommet in the firewall to the passenger side of the brake booster, remover the carpet away from the firewall (still talking about behind the brake booster area)in the engine bay and shes right there. Cut a slice or drill a small hole for your line.
Use the headlight switch power for your gauge bulb source.
Happy boosting
