1 - 4 of 4 Posts
If my check engine light comes up with P0411, is that a "fix-now or more problems will occur" type problem? I am not ever 100% sure what secondary air injection does... thanks. jered
Re: P0411 = annoying and/or harmful (Jered96VR6)
The system blows fresh air into the exhaust manifold during cold starts - keeps the ozone clean. It's more annoying than necessary, but some states require it to be in working order. It won't damage the engine, afaik. I had the same code/problem last year which was caused by a broken vacuum line to the system valve. Check the lines and the fuse.
Ryan
Discussion Starter · #4 ·
Ok, quick technical question. My light is still on and the stealership says that the valve is stuck open... so does that mean that hot exhaust is re-circulating and could possibly decrease HP and cause a slightly rough idle?? thanks. jered
1 - 4 of 4 Posts
