Ok this is so frustrating. Been dealing with this stupid EVAP issue for years. I wish I could just disable it with VAG-COM, I know if I knew the correct addresses and such in the ECU I could do that
. But anyways...
I have gotten a new used pump from a guy and he said he verifies with VAG-COM that it works. So I put a vacuum supply to it from the car and I know the hoses are fine. I hook other hose up to charcoal canister and the third intake hose is not needed, for testing purposes. Now with this old pump and the new one I still get this P1475
17883
P1475
EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open .
I noticed the purge valve was not sealing fully so I replaced it with a new used one that seals perfectly. I am still having this no signal error with the pump though and I know its not that. So its either wiring or could it be something else? I know the hoses and such are fine also. If there is a big leak in the system, shouldn't it throw a leak code? Could the charcoal canister malfunctioning be a problem? I know it has some sort of solenoid valve but I would expect that to throw a different code or just generate a leak error. But maybe I am wrong? Any ideas on this crazy thing would be greatly appreciated! Could a "damaged hose" actually cause this error? That doesn't make sense to me as it would still get a signal of some sort just throw a different leak error or something it would seem. But if this is true then problems in the charcoal canister could cause similar issues.
Thanks!
17883
P1475
Thanks!
