1 - 6 of 6 Posts
Trouble codes:
P164E00 - Oil pressure regulation valve Electrical error
static
Malfunction frequency counter: 1
Date: 2016-05-26 11:54:20
Mileage: 4511 km
Unlearning counter: 255
Unknown ambient data: 0BE12E008E576536C771209628202F0DCB11A80FC911AB000011ED1E110E0211DC000016E002
Priority: 2
Clear it and it comes right back...
First time it showed up was May 2nd..
Just have a tune "JB1" installed after May 2nd
Can't find any info on this.
If this Audi document applies to our engine too: http://www.vaglinks.com/vaglinks_com/Docs/SSP/VWUSA.COM_SSP_436_2.0L_TFSI.pdf This valve is designed to selectively allow the oil pump to run at low and high pressures. It looks like the default, unenergized state is high pressure which is a good default mode. Either way, time to see the dealer. Since you'll no doubt be pulling the JB1, double check any electrical connections at the bottom of the engine.
If the document doesn't apply, seeing the dealer still applies. :D
I just learned we DO NOT NEED A CATCH CAN!!
We already have one built in, with a return drain :heart::heart:
Hope this helps with carbon build up
Depending on the nature of the fault, a "perceptive"
driver may notice a slight variation in engine idling
speed
DAMN...
Discussion Starter · #6 ·
Made an appointment Monday 12am, see what they say..
If anyone cares, dealer pulled same code..
Odd enough my handheld reader couldn't find it.. but the obdeleven did lol
Everything tested fine, all readings good etc.. mechanic still decided to check it out.. and follow the trouble tree
1st thing he goes it says check wiring and connections.
He found the plug for that, wasn't fully seated :facepalm:
So all good :thumbup:
Will still keep an eye on it
1 - 6 of 6 Posts
