1 - 3 of 3 Posts
So this is going to be a long post
I have a mk7 gti with a apr stage 2 tune and CTS downpipe and CTS O2 spacer. All of which was on the car when I bought it. I had some codes for the downstream O2 so I replaced the O2. However I placed the wire wrong and it melted the protective sleeve against the downpipe, exposing the bare wires and shorting it. Blew the fuse associated with the O2. So I replaced the O2 sensor and now I’m left with only P2097. Could shorting it have fried something in the wiring? I’ve checked for leaks and have my spacer threaded as far out as it goes. Any help would be appreciated.
Banned
If you clear the code, does it come back? Is the vehicle operating normally? Are you confident you used the proper sensor?
1 - 3 of 3 Posts
