It seems that in warmer weather, I'm not getting the P2181 code any more. Haven't replaced any parts or adjusted coolant level to change that. ???
Have confirmed that my low speed fans are not working. Fuses are okay, fast speed works, so I'm assuming that the low speed resistors in the fan motor assemblys are shot. (My digital volt meter has died, so no measurements there yet.)
I think this is a big problem -- on a long highway drive, I got held up in stalled traffic several times. On a 66F day, after about 10 minutes idling along, my high speed fans would energize. Plugged into the OBD computer to see what was happening and found that coolant temp was cycling between about 222F and 226F with an occasional spike to 230F. (This was with the A/C off.) Can't have that happening in hot weather! Ordered two of those power resistors that I'll mount externally to restore low speed fans.
George
p.s. At highway speeds with no fans, my coolant temp was pretty steady at about 184F.
George
