P2563 Turbo Boost Control Error
1.6K views 6 replies 3 participants last post by  Dieseldog12
#1 ·
The EPC light went on in my 2015 VW Golf 1.8 TSI so I had it scanned which indicated the P256300 error code "Turbocharger Boost Control Position Sensor Circuit Range, Performance".
I removed the Turbo Boost Sensor which was quite dirty so I sprayed it down with a cleaning fluid, removing all the gunk and slapped it back into place. I then had the car error codes cleared and scanned again but the same error reappeared.
The engine itself is running well but the turbo does not engage.
From the research I have done, there could be a number of factors causing the issue. Can anyone provide guidance as to which steps should be taken next?
Any resources in the form of links or videos would be greatly appreciated.
#2 ·
Welcome toops18!
Ross-Tech, LLC
881 Sumneytown Pike
Lansdale PA 19446, USA
Tel: +1 267 638 2300​
18995/P2563/009571
Jump to:navigation, search
Contents
18995/P2563/009571 - Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) ON
  • Power Loss
Possible Causes
  • Wiring and/or Connections from/to Vane Position Sensor (G581) faulty
  • Engine Control Module (ECM) faulty
  • Vane Position Sensor (G581) faulty
    • Binding Issues due to Adjustment/Turbocharger
    • Excessive Carbon build-up
  • Vacuum Leak from/to Turbocharger (Wastegate) Actuator and Solenoid Valve for Boost Pressure Control (N75)
Possible Solutions
  • Check/Replace Fuses
  • Check Wiring and/or Connections from/to Vane Position Sensor (G581)
  • Check Vane Position Sensor (G581)
    • Perform Ohm Test
  • Check Mechanical Turbocharger Operation
    • Rule out binging and excessive Carbon build-up
  • Check Vacuum Supply from/to Solenoid Valve for Boost Pressure Control (N75) and Turbocharger (Wastegate) Actuator
Special Notes
All engines
  • This fault code may be caused when the Actual and Specified Turbocharger requests are considered Implausible by the engine controller.
Diesel
When this fault is found in the NAR Market 2.0L CR TDI:
  • Measuring Block Group 034.2 (specified) and 034.3 (actual) G581 Vane Position Sensor values can be logged to see if the fields should mirror each other or deviate to confirm a problem.
  • NAR market vehicles that had TPI 2025464 | TSB 21-11-01 -or- the latest TPI 2025464/5 | TSB 21-13-01 completed to prevent no-start conditions in cold weather caused by a frozen intercooler may want to see this thread.
Gasoline
When this fault is found in 3rd Generation VW EA888 engine such as the 2014+ Golf 6 based 1.8T/2.0T, Golf 7 and 7.5 based 1.8T/2.0T (additionally many of the 2016+ Audi EA888 based Generation 3 MLBevo) engines after wastegate repair kit installation verify the actual position is within the specified range. The easiest way to identify the 3rd Gen engine is based on the fully electric (no vacuum control) wastegate with repair kits available based on VIN at the dealer.
The following Advanced Measuring Value groups should be helpful:
  • Actual position: [*IDE00396*] Charge air pressure actuator: acknowledgment
  • Rest stop specified position: [*IDE03934*] Charge pressure actuator: adaptation for lower stop
  • End stop specified position: [*IDE03935*] Charge air pressure actuator: adaptation for upper stop
IDE00396 needs to be very near IDE03934 when the engine is off and the rod is adjusted properly. If it is within specification Basic Settings [*IDE04304*] Initial adaptation of charge-air pressure actuator should finish correctly with the key on and engine off.
Category:
Navigation menu
Categories
Tools
Unless otherwise noted, all content on this site is Copyright © 2000-2017 by Ross-Tech LLC. All rights reserved.
"VCDS", "VCDS-Mobile", "HEX-NET" and "HEX-V2" are Registered Trademarks of Ross-Tech, LLC.
Ross-Tech is not affiliated with the Volkswagen Group in any way.
#3 ·
Thank you, @fat biker . I’m a little confused and uncertain if the sensor that I was focused on was in fact the Turbo Boost because from videos that I have seen, this particular sensor in the very front and center of the engine is being considered the MAP.
Are the MAP and Turbo Boost sensor referred to one another interchangeably and if not then where is the Turbo Boost sensor to be found/how to access it?
#5 ·
The sensor just is just a way for the ECU to determine if its reaching boost its requesting so it can adjust fueling.
I'm 99% sure the issue you have is a stuck wastegate most likely due to a failed wastegate actuator (WGA). The WGA itself has a sensor to determine its position so it can range from 0% to 100% open, its a stupid feedback loop.
The EA888.3 turbos and bolted on wastegate actuators are known to not be the most reliable.
Do some searches here of my posts. You can just replace the WGA, but the problem may pop backup. If you want the sure fire way to fix the issue (dealer method) it'd be a turbo replacement.
#4 ·
#7 ·
Whole new turbo?
FCP euro would be my go to place.
If the wastegate rod isn't moving but you can feel some play at the linkage at the turbo, thats usually the WGA internals ate itself and is locked up, a common failure on the worm gear style.
What'd you find out from the shop visit?
