1 - 5 of 5 Posts
over from the mk2 forum
specs-obd1 swap,autotech 270 cam,stock injectors,stock chip
I finally started the car and here are my issues
1-Car runs very rich at idle(wideband reads 11.4to 10.3
2-sputters up until 3k rpm.
a-Under load and above 3k rpm the car is great(afr is 13.8-14.7)
3-car stalls coming to a stop.
4-The oil buzzer is going of over 3k.(have confirmed great oil pressure)
a-How can i turn of the buzzer i have the sensor grounded and it still goes off
5.I cant scan my ecu,keeps telling me to cycle key
a-i could scan it up until a day or so ago
b- codes where tps shorted to ground and ect sensor shorted to ground
6.I went to test the tps.I did not get 5 volts only .35(testing between pins 1-3)but when grounding the sensor i get 5volts.
a- the ground for the tps meets the ect sensor ground somewhere.I think thats where my problem is.But where is the ground
I have got new plugs and a new o2sensor coming tuesday for it
I have test the maf and it is good.
I have another coil to try also because i believe it is causing the sputtering
the coolant temp gauge in the cluster works also
http://s146.photobucket.com/al...1.flv
as you see in the vid the afr is good here but after more time running it goes to about 10.4 to 11.4
Re: Paging 2.0 guys.Got some issues (Daskoupe)
Sounds like a vacuum issue or maybe the O2 sensor or the TPS.
Seems like the computer isn't reading the a/f right.
Also seems like you're already hunting down things that may be the culprit.
You seem aware of your engine, I'm sure you'll have it sorted in no time.
-Dave
Re: FV-QR (Daskoupe)
I had a problem like this with my 2.0 when I first got it. It would sputter and act like it was dying until a little over 3 grand. I had a tps code a maf code and o2 code. It turned out to be the maf. I guess it was actually a recall too on some of the obd1 cars.
1 - 5 of 5 Posts
