My MK2 didn't look too bad from a few feet away but it's got a lot of small dents and scratches. The roof was developing some surface rust and there are some other spots here and there. After speaking with every body/paint shop in the area and against my better judgement, I decided to try the repairs, bodywork, and paint by myself. I found a perfect hood at the JY and some replacement doors on CL that were in better shape than mine, not perfect though. All the work is being done outside and for the most part, on a gravel driveway :thumbdown:
Last weekend I finally sprayed the first two coats of epoxy after 80+ hours of sanding, etc. Here are some progress pics.
Before work started:
Initially I didn't think I was going to use an epoxy primer so I started body work on bare metal. Not against the rules and lots of guys still do it, but considering that the car is exposed to the elements being worked on outside, I wish I would have waited to do body work until after the epoxy is sprayed only because I've needed to scuff the surface rust every few days. Not a huge deal.
Used 80 grit down to metal, applied filler and block sanded, filler and sanded, then applied glazing putty to fill in the bondo 'pores', then sanded flat again:
Found some rust around one of the rear window. Used a por-15 like product and decided to treat the whole window. I'm just going to leave it on there and paint over it in hopes it prevents those rust-prone spots from being a problem in the future.
Then I decided to shave my rear emblems and window wiper. Without the ability to weld, this is how I chose to do it, I used the pop-out plugs of a conduit junction box and metal adhesive to secure them to the back of the panel, then used filler/glaze on the front. I welcome your trolling this thread about how I'm doing it the 'ghetto' way.
My 30 gal air compressor was waaaaaay too small to power the DA so I bought an electric one at Home Depot. Worked great. Then realized that if some of it was going down to bare metal, might as well take it all down for continuity. This was when I realized I'll end up spray epoxy as well as urethane primer.
The hood alone took me at least 6 hours with the DA to get it down to metal!
I've gotten to know the guys at a body shop literally right down the street from my house, brought them coffee and donuts and picking their brain about what I'm doing right, what's next, etc. Put parts of it back together and drove it down the street to get their opinions on my progress.
And then after taking it all down to metal with the DA, I went over it all by hand still with 80 to get it even smoother and try to leave as little OG sealer as possible. The hood looked like a freshly honed cylinder! Then, because it's been outside, I continued to sand/scuff every part over the next couple of week as I masked and got it ready for epoxy.
Then, I sprayed for the first time! Made some seriously classic new guy mistakes that I'm now correcting, but all in all, it turned out well. After so many hours of researching every aspect of this project, I decided to use SPI epoxy, urethane, and clear coat. For primers I'm using the Harbor Freight hvlp gun. For $16 it's almost cheaper to just throw them out after each stage instead of clean them, that epoxy is sticky as hell! 1 coat was approximately 1.5 qts of sprayable product. For the first spray I wanted to do it without any type of diy-booth or fans just to see what I'm up against. Got quite a few dust nibs and such but not too bad. Wrapped the threads to my gun's paint cup with teflon tape that ultimately made it out the tip of my gun and into the paint
Also had the fluid adjust turned so far out that on my first spray, the spring popped it off and it just started dumping paint all over the hood from the tip :facepalm: hmmm... I know there was something else I did that just seemed so stupid, can't remember. Anyway, here it is after blocking again, scuffing, wax and grease remover, tack rag, then epoxy primer:
That was a week ago and today I started blocking it out again but with 120. It sands a lot better than what I expected, I could have used 220 or even higher. Blocking is easy with the primer because of how glossy it is you don't need any type of guide coat. Once it's all blocked, I'll scuff it all again, W&G, tack, another coat of epoxy, then 3 coats of urethane primer and do it all over again! Hoping to get that sprayed next weekend. There were also some spots that I didn't mask particularly well and left some metal exposed. I bought some rope and shimmed it underneath the weatherstripping to pull it away from the panels so that paint can get underneath, also pulled the windshield molding so that'll be a lot better.
