Paintwork Problem
436 Views 5 Replies 4 Participants Last post by  VRSexed
Paintwork Problem (please read, and give advice)
I washed my car yesterday, and on the roof loads of pin sized bubbles have appeared under the paint..... The paintwork in original, can anyone tell me why this has happened, and how i can cure this problem....
[Modified by DubVR6, 10:17 PM 12-2-2001]
See less See more
1 - 6 of 6 Posts
Re: Paintwork Problem (DubVR6)
I have maybe...2 itty bitty spots also, just not on the roof, 1 on the door, one near the sideskirt. Anyone got any tips of trying to stop the rust?
Can you be more specific? Is it little bubbles under the clear coat, or little bubbles under the base coat? As well are these little bubbles raised, or more of a little bubble that has been popped?
Re: Paintwork Problem (VRSexed)
the bubbles are raised up, the water seems to be under the clear coat. If you push them with your finger nail you can see the water moving underneath...... It has been raining here for the last week, it seems as if the water has seepes in through the clear coat........
See less See more
your clear coat is going. Only fix is to have it re painted.
Re: Paintwork Problem (GAIO GTI)
quote:[HR][/HR]your clear coat is going. Only fix is to have it re painted. [HR][/HR]​
You might be able to get away with not re-painting the base, but the clear will have to definately be re-done. Is this an OEM finish on your car we are talking about?
1 - 6 of 6 Posts
