41 - 60 of 135 Posts
Hello, I'm new into this forum and sorry I'm French so, I speak english for expose my problem.
I have on my Octavia 2 Facelift year 2010 retrofitted OPS parking system and it work perfectly and I want to retrofit Park Assist but when I use VAG.COM for coding the module 44, I have this error message :
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Control Module Part Number: 1K0 909 144 J
Component and/or Version: EPS_ZFLS Kl. 69 3001
Software Coding:
Work Shop Code: WSC 73430 790 00999
VCID: 3147C7F0D40C
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 25877 km
Time Indication: 0
Date: 2014.14.07
Time: 02:10:23
Freeze Frame:
Voltage: 11.63 V
DD
Temperature: 29.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
I have an MK60EC1 ABS module and a module 10 1T0919475C
Why this message appear please ?
Very thank
Regard
:)Hi, newby here! picking up my golf R(with rns510) in thr morning 6 months old and with the wifes driving need to fit the ops asap, but found this thread and will hold off a while and do the full park assist with ops in one hit i think. Looking forward to a full step by step if possible!! it may just about save the bumpers being painted every month :)
Discussion Starter #43
Trying to find some reference to my ABS module in ETKA, but so far not found anything with the same part number - looking at illustration 614-10. It shows the part number as 1K0 907 375 maybe it's somewhere else in ETKA??
For my MK6, my ABS module is 1K0 907 379 AJ. I scanned another GTi with park assist and his ABS module part number is 1K0 907 379 BE, but his car was a later model, so not sure if this is just a running change, or specifcially needed for park assist.
Mk60ec1
Just only to be prepared if my ABS Control Module does not work MK60 (1K0 907 379 AC) I bought this used Control Module which is MK60EC1 (1K0 907 379 AJ). I hope there are no compatibility issues.
Waiting the part from German eBay:
http://www.ebay.de/itm/ATE-VW-ESP-Steuergeraet-Controller-1K0907379AJ-/120673873117
I will install the Park Assist with the current ABS Module and report back, if it fails, I will install the MK60EC1 version and expect results.:facepalm:
Still waiting the MK60EC1 ABS Module part.
Im still waiting for the MK60EC1 ABS unit from Germany, nontheless I will install with the current ABS, but I want to have it ready the replacement in case it does not work. :thumbdown:
Not yet since I got troubles sourcing the ABS Module, good news is that I will get it next Monday.
It will take me some time to install since I recently got married, so I need to put my head back on the track :p
Discussion Starter #56
can understand time issues - been trying to finish up camera retrofit for almost 6 months now. did a bit today, just need to locate a new fuse!
Park Assist Button Pins
@Beloux
I have connected the Park Assist Button, BUT it seems the pins for the button on the diagram are incorrect or need the hole stuff connected (module, sensors etc) to be iluminated.
I have to connect Pin 3 for Ilumination and Pin 6 to Ground (as the other buttons) which in the diagram indicates is Pin 4 and 2 for Ground.
MAYBE it needs to be connected all together to be iluminated the way is intended.
:confused:
Can you confirm?
I had a little time and just connected the button for the looks at the moment.
Pic
Looking very nice. Sub'd for updates. I'm seriously considering adding at least the OPS part to my car (not sure about the auto parallel parking since US spec cars might not have the right modules for it though.)
