2003 allroad C5, Alpaka Beige with tan/Brown Interior
Located in Gig Harbor WA
2.7t, 110,000 miles on motor.
following done at 96,000 miles:
new timing belt
thermostat/housing
waterpump
G-12 coolant
new expansion tank
new torque converter
new drive axles
front control arms
piggie pipes
turbo gaskets x2
Make offer on the motor
APR ECU $300
https://www.goapr.com/products/ecu_upgrade_a627t.html
new FEBI Bilstein upper front/rear control arm links right and left $100 ea
new TRW front lower rear control arms right and left $150 ea
ECS Brakes with stainless lines $600
Front Big Brake Kit - Stage 2 - 2-Piece Cross Drilled & Slotted Rotors (331x32) ES#517843
Red ECS Calipers & 2-piece Cross-Drilled & Slotted Zinc Plated Rotors
B7 S4 rear brake calipers and slotted rotors Akebono pads $400
new in box Arnott air compressor $225
Hazard switch $15
1998-2005 C5 AUDI HAZARD SWITCH TRIM ALLROAD REAL WOOD WOODGRAIN A6 S6 4B0863321 $20
Trim is in good shape, seats, door cards available
Let me know if you need any parts, if interested in the motor, make me an offer
I can ship but Prices do not include the ride to your house.
Ill keep it for 2 weeks then ill chop it up and haul it off.
Pics available on request
new timing belt
thermostat/housing
waterpump
G-12 coolant
new expansion tank
new drive axles
front control arms
piggie pipes
turbo gaskets x2
APR ECU $300
Hazard switch $15
