1 - 16 of 16 Posts
Banned
Engine Performance
42 DRAFT DESIGNS PARTS
42 Draft Designs VW MK5/MK6 FSI High-Flow Intake System
PLEASE ORDER HERE
42 Draft Designs VW MK5/MK6 TSI High-Flow Intake System
PLEASE ORDER HERE
AUTOTECH SPORT TUNING PARTS
Autotech Composite Cold Air Intake Kit '08.5+ MK5 MK6 TFSI 2.0T CBFA eng. code
PLEASE ORDER HERE
Autotech Composite Cold Air Intake Kit '08.5+ MK5 MK6 TFSI 2.0T CCTA eng. code
PLEASE ORDER HERE
Autotech FSI High Pressure Fuel Pump Upgrade Kit
PLEASE ORDER HERE
42 Draft Designs MK6 Golf R FSI Ultimate Oil Catch Can Solution
PLEASE ORDER HERE
42 Draft Designs O2 Sensor Spacer
PLEASE ORDER HERE
Autotech High Volume Fuel Pump Upgrade Kit 2.0T FSI
PLEASE ORDER HERE
Lower Engine Mount Insert, Mk5/6 GTI, Jetta & Rabbit
PLEASE ORDER HERE
EVOMS 2.0T TSI V-Flow Intake
PLEASE ORDER HERE
BSH TSI 2.0T Race Intake
PLEASE ORDER HERE
BSH TSI 2.0T True Seal Intake
PLEASE ORDER HERE
BSH TSI Competition Catch Can
PLEASE ORDER HERE
BSH/Synapse TSI DV Relocation Kit
PLEASE ORDER HERE
BSH 2.0 TSI Integrated Throttle Body Pipe
PLEASE ORDER HERE
BSH Boost Tap for VAG 2.0T FSI & TSI
PLEASE ORDER HERE
VW 2.0T Stage 2 Front Mount Intercooler With all Pipework
PLEASE ORDER HERE
Banned
Discussion Starter · #2 · (Edited)
Forge Motorsports
Blow Off Adaptor for VAG 1.4 TSi Engines
PLEASE ORDER HERE
Blow Off Adaptor for VAG Turbo Engines
PLEASE ORDER HERE
Charcoal Canister Cover
PLEASE ORDER HERE
Forge Actuator for VAG 90-150 hp 1900cc Diesel Engines with Garrett VNT turbo
PLEASE ORDER HERE
Forge Alloy Radiator for VAG 2.0 TFSI Engined Cars
PLEASE ORDER HERE
Forge Blow Off Valve for VAG TSI 1.4 Twincharged Engines
PLEASE ORDER HERE
Forge Blow Off Valve Kit for VAG 1.4T 1.8T 2.0T Engines
PLEASE ORDER HERE
Forge Induction Kit for MK6 GTI (Non US Spec)
PLEASE ORDER HERE
Forge Induction Kit for MK6 GTI 2 Litre
PLEASE ORDER HERE
Forge Induction Kit for the MK6 Golf R
PLEASE ORDER HERE
Forge Intercooler for MK6 Golf R (US Models Only)
PLEASE ORDER HERE
Forge Oil Catch Can Kit for VAG TSI Engines
PLEASE ORDER HERE
Forge Recirculation Valve for VAG 1.4 TSi Twincharged Engines
PLEASE ORDER HERE
Forge Silicone Turbo Hoses for MK6 Golf R
PLEASE ORDER HERE
Forge Twintake Induction System VAG 2.0T
PLEASE ORDER HERE
Forge Valve Small Spring Tuning Kit
PLEASE ORDER HERE
Forge Washer Bottle Cover for VAG applications
PLEASE ORDER HERE
KO4 Upgrade Actuator
PLEASE ORDER HERE
PLEASE ORDER HERE
Oil Breather Filter 28mm i.d. connection
PLEASE ORDER HERE
Oil Catch Tank Kit For VAG TFSi
PLEASE ORDER HERE
Replacement Valve for 2.0litre FSIiT TFSi Engines
PLEASE ORDER HERE
Silicone Boost Hoses for 140 HP 2.0 TDI
PLEASE ORDER HERE
Twintercooler for MK6 GTI 2 litre Turbo
PLEASE ORDER HERE
Washer bottle filler
PLEASE ORDER HERE
Banned
Discussion Starter · #3 · (Edited)
CTS Turbo
BorgWarner K04-0064 2.0T OEM Audi S3
PLEASE ORDER HERE
CTS Diverter Valve Relocation Adapter FSI / TSI
PLEASE ORDER HERE
CTS Drop In High Flow Fuel Pump Kit For FSI/TSI
PLEASE ORDER HERE
CTS MK5/MK6 TSI Crank Pulley Kit
PLEASE ORDER HERE
CTS MK6 2.0T Direct Fit FMIC Kit
PLEASE ORDER HERE
CTS MK6 Golf R 2.0T Direct Fit FMIC Kit
PLEASE ORDER HERE
CTS MK7 GTI FMIC KIT
PLEASE ORDER HERE
CTS TURBO - TSI BREATHER ADAPTER for 2.0T
PLEASE ORDER HERE
CTS Turbo 02E DSG Cooler Kit
PLEASE ORDER HERE
CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1)
PLEASE ORDER HERE
CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1)
PLEASE ORDER HERE
CTS Turbo Air Filter 2.75" Inlet Low Profile
PLEASE ORDER HERE
CTS Turbo Blow Off Adaptor for VAG FSI, TFSI, TSI Turbo Engines
PLEASE ORDER HERE
CTS Turbo Dual Port Boost Tap TSI/FSI/Golf R
PLEASE ORDER HERE
CTS Turbo FSI/Golf R Intake Manifold Flap Delete
PLEASE ORDER HERE
CTS Turbo Gen 3 Crank Pulley Kit
PLEASE ORDER HERE
CTS Turbo Gen 3 Direct Fit FMIC Kit
PLEASE ORDER HERE
CTS TURBO GOLF R 2.0 TFSI TURBO KIT
PLEASE ORDER HERE
CTS Turbo Golf R Turbo Outlet Pipe (TOP)
PLEASE ORDER HERE
CTS Turbo Golf R/FSI 3" Intake System
PLEASE ORDER HERE
CTS Turbo Golf R/TT-S Catch Can Kit
PLEASE ORDER HERE
CTS Turbo Heat Shield Golf R / FSI Specific
PLEASE ORDER HERE
CTS Turbo Intake Manifold Plug
PLEASE ORDER HERE
CTS Turbo MK6 1.4L Twincharger Intake System
PLEASE ORDER HERE
CTS Turbo MK6 2.0 TSI BorgWarner K04 Turbo Upgrade Kit
PLEASE ORDER HERE
CTS TURBO MK6 2.0 TSI TURBO KIT
PLEASE ORDER HERE
CTS Turbo MK6 Golf R Air Intake System
PLEASE ORDER HERE
CTS Turbo MK6 GTI DSG Cooler Kit
PLEASE ORDER HERE
CTS Turbo MK6 TSI Catch Can Kit
PLEASE ORDER HERE
CTS Turbo PCV Revamp Kit FSI/Golf R
PLEASE ORDER HERE
CTS Turbo TSI Air Intake System EA888.1 for MK5/MK6 TSI
PLEASE ORDER HERE
CTS Turbo TSI Throttle Pipe
PLEASE ORDER HERE
CTS Turbo TSI Turbo Outlet Pipe (TOP) for MK6 GTI/Jetta & Audi A3
PLEASE ORDER HERE
CTS Turbo Valve Cover Breather Adapter 2.0T FSI
PLEASE ORDER HERE
Supertech 2.0T TSI Valve Spring/Titanium Retainer Set
PLEASE ORDER HERE
Supertech Exhaust Valve Set TSI INCONEL
PLEASE ORDER HERE
Supertech Intake Valve Set TSI
PLEASE ORDER HERE
Banned
Discussion Starter · #4 · (Edited)
Black Forest Industries
BFI "Clean Catch" - Crankcase Oil Separator (Transverse FSI/Golf R)
PLEASE ORDER HERE
BFI "Clean Catch" - Crankcase Oil Separator (Transverse TSI)
PLEASE ORDER HERE
BFI "Clean Catch" Crankcase Oil Separator - Essential Kit EK (Transverse FSI/Golf R)
PLEASE ORDER HERE
BFI "Clean Catch" Crankcase Oil Separator - Essential Kit EK (Transverse TSI)
PLEASE ORDER HERE
BFI "Clean Catch" Crankcase Oil Separator - Essentials Kit EK (2.5L 5-Cylinder)
PLEASE ORDER HERE
BFI "Clean Catch" Crankcase Oil Separator - Vent To Atmosphere (2.5L 5-Cylinder)
PLEASE ORDER HERE
BFI Clean Catch Crankcase Oil Seperator - Essential Kit EK (Transverse FSI)
PLEASE ORDER HERE
BFI MK5/MK6 Stage 1 Engine Mount (5-cylinder)
PLEASE ORDER HERE
BFI MK5/MK6 Stage 2 Engine Mount ('09+ TSI 4-cylinder)
PLEASE ORDER HERE
BFI MK5/MK6 Stage 2 Engine Mount (5-cylinder)
PLEASE ORDER HERE
BFI MK5/MK6 Stage 2 Trans Mount (5-speed & Tiptronic)
PLEASE ORDER HERE
BFI MK5/MK6 Stage 3 Engine Mount ('09+ TSI 4-cylinder)
PLEASE ORDER HERE
BFI Stage 1 Torque Arm Insert ('09+)
PLEASE ORDER HERE
BFI Stage 2 Torque Arm Insert ('09+)
PLEASE ORDER HERE
BFI Stage 3 Mount Replacement Inserts for EOS
PLEASE ORDER HERE
Banned
Discussion Starter · #5 · (Edited)
Sport Exhausts
42 Draft Designs VW MK5/MK6 FSI/TSI 3" Downpipe
PLEASE ORDER HERE
42 Draft Designs VW Mk6 Golf R FSI 3" Cat-Back
PLEASE ORDER HERE
42 Draft Designs VW MK6 Golf R FSI 3" Downpipe
PLEASE ORDER HERE
42 Draft Designs VW Mk6 Golf R FSI 3" Turbo-Back
PLEASE ORDER HERE
42 Draft Designs VW Mk6 GTI TSI 2.5 & 3 Inch Cat-Back
PLEASE ORDER HERE
42 Draft Designs VW Mk6 GTI TSI 2.5 & 3 Inch Turbo-Back
PLEASE ORDER HERE
AP VW GTI Catback Exhaust System 2.0TFSI (2 Door Only)
PLEASE ORDER HERE
CTS FSI TSI Golf R Turbo Manifold T3 Flanged
PLEASE ORDER HERE
CTS noise pipe delete kit for FSI/TSI motors
PLEASE ORDER HERE
CTS Turbo Gen 3 1.8T/2.0T TSI Downpipe
PLEASE ORDER HERE
CTS Turbo Golf R 3" Cat Back Exhaust
PLEASE ORDER HERE
CTS Turbo Golf R 3" Turbo Back Exhaust
PLEASE ORDER HERE
CTS Turbo MK6 Golf R/TTS Downpipe
PLEASE ORDER HERE
CTS Turbo MK6 GTI 3" Cat Back Exhaust
PLEASE ORDER HERE
CTS Turbo MK6 GTI 3" Turbo Back Exhaust
PLEASE ORDER HERE
CTS Turbo MK6 TSI 2.0T FWD Downpipe
PLEASE ORDER HERE
HPA Quad Pack Exhaust for Golf R
PLEASE ORDER HERE
Jetex 3 Inch Duplex Tips Stainless Steel Catback Exhaust for MK5 Golf, GTI & 8P A3
PLEASE ORDER HERE
Jetex 3 Inch Stainless Steel Catback Exhaust for MK6 GTI
PLEASE ORDER HERE
Jetex 3 Inch Twin Round Tips Stainless Steel Catback Exhaust for MK5 Golf, GTI & 8P A3
PLEASE ORDER HERE
Jetex Back Box with Duplex, Single Round Tips for MK5, MK6 Golf & 8P A3 TDI
PLEASE ORDER HERE
Jetex Back Box with Quad, Twin Round Tips for MK5, MK6 Golf & 8P A3 TDI
PLEASE ORDER HERE
Jetex Back Box with Twin Round Tips for MK5, MK6 Golf & 8P A3 TDI
PLEASE ORDER HERE
Jetex Full Cat-Back System for Golf R
PLEASE ORDER HERE
Banned
Discussion Starter · #6 · (Edited)
Drivetrain
42 Draft Designs VW 6S Shifter Cable Support Bracket
PLEASE ORDER HERE
42 Draft Designs VW Shifter Bushing Set - Mk6 6S MY10-13
PLEASE ORDER HERE
BSH 2.5L / 3.2L / FSI 2.0T Pendulum Mount 2006-2008 (Includes Torque Mount)
PLEASE ORDER HERE
BSH 2.5L Side Engine Mount
PLEASE ORDER HERE
BSH FSI/TSI Engine Mount
PLEASE ORDER HERE
BSH FSI/TSI Engine Mount Package
PLEASE ORDER HERE
BSH FSI/TSI/R32 Transmission Mount
PLEASE ORDER HERE
CTS Turbo Billet Subframe Bushing Insert Kit: MK5/MK6/MK2 Audi TT
PLEASE ORDER HERE
CTS Turbo O2M/O2Q Short Shift Kit
PLEASE ORDER HERE
HPA 02M Short Throw Shifter for VAG 6 Speed
PLEASE ORDER HERE
HPA Mk5/Mk6 Pendulum (Dog Bone) Mount HVW-904-75
PLEASE ORDER HERE
HPA Mk5/Mk6 Pendulum (Dog Bone) Mount HVW-904-80
PLEASE ORDER HERE
HPA Mk5/Mk6 Pendulum (Dog Bone) Mount HVW-904-85
PLEASE ORDER HERE
HPA Mk5/Mk6 Pendulum (Dog Bone) Mount HVW-904-90
PLEASE ORDER HERE
VF-Engineering Engine Side Mount for MK5, MK6, MK2 TT & 8P A3
PLEASE ORDER HERE
VF-Engineering Rear Engine Mount for MK6 VW
PLEASE ORDER HERE
VF-Engineering Transmission Mount for MK5, MK6, MK2 TT & 8P A3
PLEASE ORDER HERE
VW / Audi 6 Speed Short Shift Kit
PLEASE ORDER HERE
Wavetrac Differential, 2WD DSG VW MK5 MK6 Audi 02E A3 TT S-Tronic [20T RING]
PLEASE ORDER HERE
Wavetrac Differential, 4WD Quattro Front DSG VW MK5 MK6 Audi 02E A3 TT S-Tronic [25T RING]
PLEASE ORDER HERE
Wavetrac Differential, VW 02Q 2WD 6 spd. manual
PLEASE ORDER HERE
Wavetrac Differential, VW Audi DSG 2WD [25T RING] MK6 GTI A3/TT 2.0T
PLEASE ORDER HERE
Banned
Discussion Starter · #7 · (Edited)
Suspension
APR 27mm Roll Control Rear Sway Bar for MK5 GTI & GLI, Audi A3 8P 2006, MK6 GTI & GLI
PLEASE ORDER HERE
AUTOTECH ClubSport 25mm HOLLOW ADJUSTABLE FRONT SWAYBAR, Mk5 Mk6 & AUDI A3
PLEASE ORDER HERE
AUTOTECH ClubSport 25mm HOLLOW ADJUSTABLE REAR SWAYBAR, Mk5 Mk6 & AUDI A3
PLEASE ORDER HERE
Bilstein B16 PSS10 Coilover Kit for MK6 Golf, GTI, Jetta & MK3 Scirocco
PLEASE ORDER HERE
ClubSport STAGE I, Mk5/Mk6 GTI 2.0T
PLEASE ORDER HERE
Eurojet Sway Bar Endlinks for VW MK5, MK6, B6
PLEASE ORDER HERE
FK High Tec Sport Suspension Kit for MK5 & MK6 (35-40mm)
PLEASE ORDER HERE
FK High Tec Sport Suspension Kit for MK5 & MK6 (50-44mm)
PLEASE ORDER HERE
FK Highsport Coilover Suspension Kit for Audi 8P & VW MKV, MKVI, B6
PLEASE ORDER HERE
FK Konigsport Coilover Suspension Kit for Audi 8P & VW MKV, MKVI, B6
PLEASE ORDER HERE
FK Silverline Coilover Suspension Kit for Audi 8P & VW MKV, MKVI, B6
PLEASE ORDER HERE
FK Silverline X Coilover Suspension Kit for Audi 8P & VW MKV, MKVI, B6
PLEASE ORDER HERE
FK Street-Line Coilover Suspension Kit for Audi 8P & VW MKV, MKVI, B6
PLEASE ORDER HERE
H&R Street Coilover Kit MK6 Golf/GTI all
PLEASE ORDER HERE
H&R Street Performance SS Coilover Kit for VW Golf, GTI MKVI
PLEASE ORDER HERE
H&R Ultra Low Coilover Kit MK6 Golf/GTI all 3.1" drop
PLEASE ORDER HERE
Hotchkis 27mm Rear Sport Sway Bar for Audi A3 8P & VW Golf, GTI, Jetta Sportwagen, Rabbit MK5, MK6
PLEASE ORDER HERE
Passat B6 Cast Alum Lower Front Control Arm Kit (Pair)
PLEASE ORDER HERE
RSK Street Coilover Kit for Late Model VAG Vehicles
PLEASE ORDER HERE
RSK Street Plus Coilover Kit for Late Model VAG Vehicles
PLEASE ORDER HERE
Solo Werks S1 Coilover Suspension Kit for AUDI 8P A3, MK2 TT & VW MK5, MK6
PLEASE ORDER HERE
Solo Werks S1 Coilover Suspension Kit for AUDI 8P, MK2 TT & VW MK5, MK6, B6 & B7 Passat
PLEASE ORDER HERE
ST Coilovers MK6 Golf all
PLEASE ORDER HERE
Stabila Street MK5/MK6/A3/TT Rear Sway Bar (25mm)
PLEASE ORDER HERE
Stabila Street R32/Golf R/A3/TT 4Motion/Quattro Rear Sway Bar (25mm)
PLEASE ORDER HERE
Vogtland Damping Adjustable Coilovers - MK6 GTI / Golf - 30-65mm
PLEASE ORDER HERE
Vogtland Height Adjustable Coilovers - Mk6 GTI / Golf - 30-65mm
PLEASE ORDER HERE
VW MK5/MK6 Upper Strut Mount
PLEASE ORDER HERE
Banned
Discussion Starter · #8 · (Edited)
Pods & Gauges
42 Draft Designs Boost Gauge Tap for VAG 2.0T FSI & TS
PLEASE ORDER HERE
Boost Gauge Fitting Kit for VAG 2 litre FSiT & TSI
PLEASE ORDER HERE
PLEASE ORDER HERE
Forge Boost Gauge Adaptor for VAG 1.4 TSI
PLEASE ORDER HERE
MK6 ColumnPod
PLEASE ORDER HERE
MK6 Dual ColumnPod
PLEASE ORDER HERE
NewSouth 2.0 TFSI/FSI BanjoPort
PLEASE ORDER HERE
NewSouth Mk5/Mk6 ConsolePod
PLEASE ORDER HERE
NewSouth MK6 Golf R Turbo VentPod
PLEASE ORDER HERE
NewSouth MK6 Golf R TurboPod
PLEASE ORDER HERE
NewSouth Mk6 Turbo VentPod
PLEASE ORDER HERE
NewSouth Mk6 TurboPod
PLEASE ORDER HERE
NewSouth MK6 VentPod
PLEASE ORDER HERE
NewSouth NoBuzz TDI Boost Tubing Kit
PLEASE ORDER HERE
NewSouth TSI 3rd Gen, VW/Audi 2.0 TFSI & Audi A4 2.0 FSI NoBuzz Fitting Kit
PLEASE ORDER HERE
NewSouth VW 2.0 TSI MultiTap Hose
PLEASE ORDER HERE
NewSouth VW RedLine 0-30 in hg, 0-30 PSI Boost Gauge
PLEASE ORDER HERE
NewSouth VW White 0-35 PSI Boost Gauge With TDI Fitting
PLEASE ORDER HERE
NewSouth VW White 100 PSI Oil Pressure Gauge
PLEASE ORDER HERE
NewSouth VW White Boost Gauge
PLEASE ORDER HERE
NewSouth VW White R 0-30 in hg, 0-30 PSI Boost Gauge
PLEASE ORDER HERE
O-Pod Dual ABS Plastic
PLEASE ORDER HERE
O-Pod Dual Gloss Carbon
PLEASE ORDER HERE
O-Pod Mono GT6
PLEASE ORDER HERE
P3Cars VW MK6 Golf GTI JSW Vent Integrated Digital Interface
PLEASE ORDER HERE
Bought and paid for a 2010 GTI Euro Style Bumper Order #34079, sent two email requesting when this item will be shipped with no response. Been over a week that it been ordered with no follow up to my order whatsoever. My email address is [email protected] if I don't here from you by the end of the week I'm cancelling me order thru MasterCard. I'm really not impress with your service ignoring a customer is not the way to do business. You don't even have a phone number on your site that a customer can call and talk to someone, that sucks as well. I'm not some young punk smart ass, I'm a 59yrs old car guy that expect to be treated like a customer!
Banned
Discussion Starter · #10 ·
Thanks for your order, we apologize for the delays, our warehouse is following up the order. We also replied your email.
Thank you for the quick response! If your shipping people sent me an email about the mailing address I did not receive it. Can they forward that email to me again? I apologize it had to come to this but wasn't getting anywhere with email and with no phone number to follow up with makes it difficult to be comfortable about the purchase.
Banned
Discussion Starter · #12 ·
Not a problem!
1 - 16 of 16 Posts
