in irish bear with me, missus bought a 2010 passat 1.6 tdi bluemotion manual trans. Engine code CAY? i checked over the car so this is my fault but on day 2 of ownership the car began to overheating. its had a new belt and pump 40,000km ago and diesel gate fix 70,000km ago
symtoms : after about 10 minutes of any kind of driving, going up hill will cause the temperature gauge to rise. highest temperature according to gauge was 120C.
no visible signs of over heating, was slightly low on coolant topped it off. coolant in the tank was watered down a lot and gone more of a brown color than red. cabin heaters were lukewarm not exactly boiling hot.
actions taken : drained the cooling system without thermostat removal due to time restraints, put garden hose through radiator one on both end blocking the opposite end a few times wasnt too bad. next up did the heater matix hose in the inlet not too bad some grit, went the opposite way and flow was slow and started to see bits of grit then bam a hole load of crap came out of it.
put regular coolant in and burped the system with cap off, test drove and symtoms were improved greatly, heaters putting out better heat and not overheating as quickly or as frequently, now most of the time the gauge will only creep off the 90 to maybe 100C and go back down on its own during normal driving, but introduce some hills for a perlonged period and it will creep up to 115C, ill turn on the heaters at this stage and bring the temp down manually also the radiator fans will be on.
another symtom : neither top or bottom rad hoses are hot to the touch? even with such high temp shown on the dash?
i have ordered a new thermostat from the main dealer €35 hopefully fit it at the weekend.
basically i have not much knowledge if VW passat 1.6 tdi and looking for advise if some one else has had this problem and fixed it, i have been googling endlessly and not gotten much joy also this is the second forum ive joined as the other is like a ghost town 😞
sidenote : the car had not had an oil service for 40000km i found out and i changed the oil and filter, the old filter was collapsed and clogged up. oul temps are down about 20C since
please help
Thanks
please help
Thanks
