1 - 17 of 17 Posts
· Banned
I have a 2002 passat which is a 170hp 1.8T and a 2001 jetta which is a 150hp 1.8T......can i take whatever makes the passat faster out of it and put it in my car???? cus i really doubt my mom needs it considering she burns the clutch in every shift and stalls 4 times a day
this pic is for the people that visit a post for the pics
[Modified by Koobs, 3:38 AM 2-12-2002]
· Banned
Re: Passat faster then my jetta.....can i deal wit some pieces? (Spiro SU)
"NOPE" eh?
very interesting...........now why?
what makes the diff?
a different chip would be my guess (still just a guess though)
· Banned
Discussion Starter · #6 ·
Re: Passat faster then my jetta.....can i deal wit some pieces? (WeedWolfie420)
ah zit!
dont feel like making an new post so ill drop the Q here.
if i get the split second boost controller which adds like 30hp and an APR chip which adds around like 50hp........do i look at it as 80 more hp???
or does it turn out to be different???
Re: Passat faster then my jetta.....can i deal wit some pieces? (Koobs)
so what different between the two engines? transverse mounting in the jetta vs. in-line mounting in the passat, which means different exhaust system and intake manifolds? different chip?
No. When modding a Vehicle HorsePower doesn't just Add up.
A chip give you the Ability to remap all of the engine to work with the Additional boost added. A split Second BC would just allow you to add more boost. Using the BC to boost much more than what an APR chip would give you would not be beneficial to the life of the engine or turbo.
· Banned
Discussion Starter · #9 ·
Re: Passat faster then my jetta.....can i deal wit some pieces? (hman)
the BC is controllable..........i can set it to stock if i want by turnign i knob in my car so im not running at 14.5 psi of boost at all times....
if i had the APR chip and the BC at like 9 or 10psi would that still be bad?
what do you recommend?
dropping the BC or what?
[Modified by Koobs, 5:01 AM 2-12-2002]
· Banned
Discussion Starter · #12 ·
Re: Passat faster then my jetta.....can i deal wit some pieces? (Turbo Turd)
shweet beetle isnt the answer i was lookin for but i cant denie it
oh and thats $3000 american for that bumper...
2019 GT350R
You cannot add a chip and BCS and then get the gains from both of them added up.....it doesn't work that way, the BCS does the same thing as the chip......having a chip programmed at 14.5psi and a BCS that only goes up to 14.5psi=14.5psi no matter which one you run, therefore only getting a gain of around 40hp or so.
quote:[HR][/HR]so basically i can get the APR chip and it will do the same thing?[HR][/HR]​
The boost controller will only control the boost. A chip will optimize the boost and fuel maps to yeild more HP at the same PSI level. A chip is the better bet.
1 - 17 of 17 Posts
