1 - 6 of 6 Posts
how do you convert the stock mk2 steering wheel to a passat/corrado style? i have a passat steering wheel but the center is to big
Re: passat steering wheel conversion? (86_gti_8v)
small spline wheels need either an adapter, or the shaft to be changed. small splines came on a2s up to and including 1988.
Re: passat steering wheel conversion? (VegasJetta)
could i swap the centers of the steering wheels with eachother? they apear to be the same shape i just dont know how to get em out
you can't mod the wheel, but go "rent" a small gear puller and head to the pick-n-pull. find a '90 or newer a2 or a passat/ corrado and pull the adapter. it's just a small splined sleeve that increases the overall diameter of the shaft. or it's like 10 bucks at a stealership.
Re: passat steering wheel conversion? (DClark)
ok thanks
Discussion Starter · #6 ·
got the sleeve steering wheel is now on thanks guys
1 - 6 of 6 Posts
