Passat VR6 owners
2193 Views 10 Replies 3 Participants Last post by  Mike_Fav
What's the deal with Castrol's 5w-40 offerings ?
I did my first oil change at 5k and purchased everything from the dealer. Total w/ filter $72 Castrol edge OE 06256.
Advanced Auto has 06249 for 5qts for $27.99. Amazon has 6 pack for $48.45.
Seems like a good deal, but curious if 100% same spec oil ?
Sent from my G6
See less See more
1 - 11 of 11 Posts
As long as the oil meets VWs spec, which is the same on both containers than let your wallet choose the least expensive. This spec also applies to the 1.8 L.
Seems to be the case. I thought I read that 504/507 oil could be used too. Since it looks like 5w-30 is an option too.
Sent from my G6
See less See more
I run royal purple 5w-30 in my VR6 and have had no problems
What's confusing, is I asked the parts guy about my 5qt jug of Total Quartz I have and he said, ”Naa different motor and oil" Yet, the picture above, from the manual shows 502/504 meets spec.
So TQ 9000 5w-30 meets 504/507 which you would think the TDi spec is the harder spec to meet.
Also looks like the black bottle specs out higher than the OE. I'm sure if it meets 502 to 507 it's good enough.
Sent from my Nexus 5X using Tapatalk
The 504/507 is a low SAPS (sulphated ash phosphorous and sulphur. This was for the Newer TDIs with the Diesel Particulate Filter to keep it from clogging. Personally I would stick with the 5W40 502.00 spec oil. The 504/507 is a much thinner oil.
Did you look at the manual pic? Shows 502, 503 and 504 for the "Gasoline" motors. Which it seems, would indicate an oil meeting 502 thru 507 (which always includes 504) you'd be using an oil that is within spec.
I'm not looking to discuss 30 vs 40 weight at this point.
Sent from my G6
Ok so the "black" bottle is fine. According to Castrols website it specs a little higher too. Also 5w-30 is fine if it meets 502.
Again viscosity is one thing and film strength is another. My 2007 Dodge Ram used 5w-20. Many cars today do too. 15 weight oils are coming soon.
I feel my TDI ran hotter than my VR6 and it ran fine on a high spec 30 weight. I'm fine using a 40 weight oil, but feel the same with a 30 weight if spec'd enough.
Sent from my G6
See less See more
Here are the different oil specs for the VW engine requirement through the years. One thing to consider is the manufacturer is trying to meet the CAFE standards and the only way is with thinner/light weight oils which have a tendacy to burn off faster. VW doesn't consider it abnormal if your car is using a quart every 1000 miles. The 502.00 spec has one word that should be taken note of "ardouous". To me that sounds that this oil will stand up better. My two cents. Use whatever makes your wallet happy as they all meet the specs!
http://www.oilspecifications.org/volkswagen.php
Arduous > grueling > laborious > strenuous haha
So no other oil spec can meet those onerous demands ? Curious when VW502 was made. Early 2000's ? So it's quite possible we've advanced enough to protect with
superior blends, meeting higher # VW spec and able to deal with Arduous situations ?
What's missing from these is the oil change interval recommendation at the time they were made. VW 502 was for how long ? 5k miles ?
Also 502 replaced 500 and 501 which used an “old” oil specification from the 90's.
Or was 503 made for those "extended" 10k runs ? Then 503.01 was made for an even higher demand
yet both are superseded by a superior blend > VW504
VW 502.00
Oil for gasoline engines. Successor of VW 501.01 and VW 500.00 specification. Recommended for those which are subject to arduous conditions. It must not be used for any engines with variable service intervals or any which are referred to under other specifications.
VW 503.00
Long-life gasoline engine oil for VW cars with WIV (system for longer service intervals). Also meets ACEA A1, SAE 0W-30 or 5W-30 specification.
VW 503.01
This specification is specifically for Audi RS4, Audi TT, S3 and Audi A8 6.0 V12 models with outputs of more than 180bhp, running with variable service intervals (30,000km or 2 years). Now superceeded by the VW 504.00 specification.
VW 504.00
The VW 504 00 specification superceedes the VW 503 00 and VW 503.01 specifications. VW 504 00 oils are suitable for engines meeting the demands of Euro IV emissions standards.
VW 505.00
Passenger car diesel engine oil specification, minimum performance level CCMC PD-2. Lists viscosities SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max. evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max. evaporation loss.
5w-40 weight is in my car, but if I need to change my oil during or before winter, it'll be a high VW spec 30w oil. FYI, There are 0w-30 weight oils that meet VW 502. In fact, most oils that meet VW502 meet VW 505. Just like 504/507. Many feel strongly that a hard running motor needs a thicker oil. But if the oil specs improve and a manufacturer says it's ok. Well ? They would know, no ?
Notice VW 508/509 are 0w-20 and ok for diesels. Thinner is coming :eek:.........VW is just slow to change !
See less See more
In case you need more convincing(about oil viscosity not that I'm nuts),here are some specs from the Manufacturers websites. You'll see some 30w oils have a thicker oil viscosity at 212°F than some 40w oils. And some 5w-40 oils have a lower pour point than some 5w-30 oils. Also the TDI spec, 504/507 oil has the highest flash point and is 11.7 to the OE VW 40w oil's 12.1. Royal purple 30w oil has the least viscosity at that temp. While Castrols 0w-30 oil has a thicker viscosity than the OE 40w oil @ 100°C(212°F)
So again there is Viscosity and there is film strength. One is more important than the other
Sent from my G6
See less See more
1 - 11 of 11 Posts
