This is the Revision D which is the most current version of this part
This Original Pierburg DV is made by the same manufacturer as the Genuine VW one. Get rid of your torn or leaking diaphragm style Diverter (Turbo Recirculation) Valve. Replace it with this upgraded piston style. This is the most current and sturdy revision of this OEM DV.
Common Faults Associated with the failure of this part
•000665 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded
•000051 - Turbocharger Bypass Valve Control Circuit: Malfunction / Open Circuit
P0033
http://www.deutscheautoparts.com/View/701830130-06h145710d/0/267954
Replaces VW part numbers 06H 145 710 D, 06H145710D, 06F-145-710-B, 06F-145-710-C, 06F-145-710-G, 06F145710B, 06F145710C, 06F145710G, 06F201282, 06F201282B, 06H-145-710-D
For All 2.0Turbo engines find your Volkswagen model below
[URL="https://deutscheautoparts.com/oem-diverter-valve-dv-2-0-t-06h145710d.html"]VW > Beetle > 2012-2013-2014 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > CC > 2009-2010-2011-2012-2013-2014 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > CC > 2013-2014 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > EOS > 2007-2008 > Engine > 2.0 Turbo FSI > Repair > Turbo + Assoc
VW > EOS > 2008-2009-2010-2011-2012-2013 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > GTI > MK5 2006-2007-2008 > Engine > 2.0 Turbo FSI > Repair > Turbo + Assoc
VW > GTI > MK5 2008-2009 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > GTI > MK6 2010-2011-2012-2013 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > Jetta > MK5 2005.5-2006-2007-2008 > Engine > 2.0 Turbo FSI > Repair > Turbo + Assoc
VW > Jetta > MK5 2008-2009-2010 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > Passat > B6 2006-2007-2008 > Engine > 2.0 Turbo FSI > Repair > Turbo + Assoc
VW > Passat > B6 2008-2009-2010 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > R Models > Golf R Mk6 > Engine > Repair > Turbo + Assoc
VW > Sportwagen > 2010-2011-2012-2013 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc
VW > Tiguan > 2009-2010-2011-2012-2013 > Engine > 2.0 Turbo TSI > Repair > Turbo + Assoc[/URL]
P0033
