1 - 7 of 7 Posts
· Banned
Re: performance air filter kits (dondiesel444)
theyre oth p-flo kits using a open k+n filter but you NEED a heat shield. i'd get one if i didnt already have it http://****************.com/smile/emthup.gif das cheap yo for the filter and mounting hardware
I have the one from S-tune. It seems to work well. It's actually installed in my mk2. I had to bend the bracket a little bit to make it fit. I still don't know what the little filter is for. The thing also didn't come with instructions.
For the money you can't go wrong. I can't compare it to the airbox, though, because it's a swap.
Discussion Starter · #4 ·
Re: performance air filter kits (mk2.slow)
I was thinking of picking one up and if I find the need to, i can install some kind of heat sheild later. for the cost of a stock replacement filter, I think one of these kits is a good idea, p0lus they are re-usable filters...
mk2.slow ~ if you dont want the little filter you can send it to me since you dont need it. It is the filter for the air-pump since when you remove the airbox in a mk3/4 your remove the hose going to the air pump as well. Therefore you need a mini filter (which i do not have) for the air pump.
Re: performance air filter kits (bugasm99)
Quote, originally posted by bugasm99 »
I didn't install the air pump, so I guess I won't be needing it. Send me some $ for shipping and you can have it... if I can find it.
Email me:[email protected]
1 - 7 of 7 Posts
