1 - 20 of 26 Posts
Does it have paddle shifters or keyless start?
You could sell those. The start button (if it has one) would be easy to remove since the shifter surround is loose. To remove the start button wiring would be very difficult in a junkyard.
I think the brown paddle shifter trim pieces are NLA (if it has paddle shifters).
The shifter part that always breaks is easy to remove if it's good. You just have to press the tabs at the rear and it comes right out.
Also, the headrests are not to my taste, but somebody else might like them.
-Eric
In search of: 3DO 409 061G Trans cooler & lines...
Looking for the 4 port trans cooler in the front rh corner, P/N 3DO 409 061G, along with the lines to the trans.
also: the metal water pipe that runs across the lower back of the radiator shroud.
items 1,2, & 20.
thanks, dan
hope the link works...
items 1,2, & 20.
thanks, dan
Emailed you! Send me a picture or diagram of the metal radiator hose you're referring to. Thanks
Saw the pics, is the front bumper available?
I should have mentioned this earlier.
I bought the chrome fog light and center trim. They were well packed and arrived soon.
My zip code caused a minor issue with the shipping company but other than that it was a smooth transaction and I wouldn't hesitate to buy more parts from him.
-Eric
Is the whole part shown in post # 52 in good condition?:
http://forums.vwvortex.com/showthre...yless-Start-to-a-North-American-Phaeton/page3
If so, you could remove it and sell it.
It has tabs on both sides of the end closest to the back of the car. You can press a small screwdriver in the tabs and pop it loose easily. The shifter will move (to make this part easier to remove) if you press down on the solenoid.
This is probably the lowest price online for a new one:
http://www.vwpartsoutlet.com/oe-volkswagen/3d0713633a
This is what they look like in real life:
https://www.google.com/search?q=3d0...KEwjuva7Q0v7RAhVB2mMKHXLuA30Q_AUICCgD#imgrc=_
They go for around $85.00 used on eBay when they have them.
-Eric
front left lamp cover
I am interested in the following:
front left lamp cover from the front lamp assembly: 3D0-947-125-P
both outside mirror housings (if the paint is not flaking\peeling): 3D0-857-537-GRU & 3D0-857-538-GRU
both front puddle lamp assemblies: 3D0-945-291 & 3D0-945-292
Discussion Starter · #14 ·
Front puddle lights, do you mean the front bumper fog lights? Send me a PM
Parts available?
Hello, Is the passenger side passenger door chrome trim available and in good shape? Also would need the little nub of trim that fits rear of the chrome trim, on the rear quarter panel.
Also need a couple of other items, I'm just north of Toronto. Could I call you to discuss?
Regards, Jeff
1 - 20 of 26 Posts
