1 - 9 of 9 Posts
Hi!
I have a problems. From the beginning, the sound from the sound system disappeared. At first it disappeared and then appeared. After that, the volume from the steering wheel could not be adjusted. Later I noticed that the clock was showing the wrong time I tried to adjust it he didn't respond to it. I checked all the fuses all is ok. After checking the fuses, I found that I could no longer adjust the hardness and clearance of the shock absorbers. Pressing the button displays a menu but the central button that adjusts the hardness of the shock absorber does not respond to it is solid and cannot be turned. With the VCDS I performed a suspension test on it, the car responds by lifting and lowering both front and rear and when locking the car the shock absorbers also respond. A / C can be adjusted. I can switch radio stations or turn on CDs and switch songs. When I click on the DSP it pops up the message "The digital sound package is temporarily not available. I checked both batteries there everything is fine with the car turned off shows a bit over 12v at the running car a bit over 14v. I tried to clear the errors with VCDS but several sections Cannot be reached. Maybe can anyone suggest where to look for a problem and what could be the solution.
Thank you very much in advance.
Sunday,04,July,2021,14:01:54:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVWZZZ3DZ98001122 License Plate: MC-8382
Mileage: 260690km-161985mi Repair Order:
Chassis Type: 3D (6N0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 18 19 23 28 34 36 37 38
3C 42 46 47 52 55 62 66 68 71 72 76 77
VIN: WVWZZZ3DZ98001122 Mileage: 260690km-161985miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
23-Brake Booster -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CEX) Labels: None
Part No SW: 3D0 907 401 E HW: 3D0 907 401 D
Component: 3.0TDI EDC17A000AG 0010
Revision: --H01--- Serial number: VWX3Z0H3776337
Coding: 0406002C191F0260
Shop #: WSC 66565 257 00032
VCID: 214F93DFFB4B3829405-513C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 09L 927 760 R HW: GS1 9.1 1.4
Component: AG6 09L 3,0 TDI RdW 3606
Revision: --H04--- Serial number: 4462766
Coding: 0000001
Shop #: WSC 19530 666 59056
VCID: 4685204332253F11157-515A
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008356
Shop #: WSC 01065 000 00000
VCID: 6BD3B1F749072279AA9-515A
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: Kessy 6850
Revision: 00H22070 Serial number: VWX3Z0H3776337
Coding: 0217324
VCID: 2A5D74F3817DFB7111F-807F
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 77FB9D87054F96995E1-515A
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 K
Component: Climatronic D1 2035
Coding: 0000001
VCID: 264580C39565DF11357-8073
1 Fault Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 M HW: 3D0 937 049 M
Component: J519 6500
Revision: -4004--- Serial number: --------------
Coding: 610C0000EB2115060000000000000000
VCID: 34616A8B53B9BD81BB3-8061
Address 13: Auto Dist. Reg Labels: 3D0-907-567.lbl
Part No SW: 3D0 907 567 L HW: 3D0 907 567 L
Component: AC201 RDW 1 031 0701
Revision: 00031000 Serial number: 00000000023702
Coding: 0010000
Shop #: WSC 65793 128 08224
VCID: 3567578F58C3A4898CD-8060
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0H Airbag 8.4E+ H12 0935
Coding: 0012360
VCID: 254787CFE863D4093CD-8070
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 L
Component: J527 3601
Coding: 0001022
VCID: 48992E7B3F312961E7B-801D
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No SW: 3D0 920 885 P HW: 3D0 920 885 P
Component: J285 KOMBI-INST. 5432
Revision: KPH06V16
Coding: 0007101
Shop #: WSC 11111 111 11111
VCID: 377B5D8746CF56999E1-8062
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 22
Mileage: 260696 km
Time Indication: 0
Date: 2021.07.04
Time: 13:38:35
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3D0 920 885 P
Component: J533 GW-K-CAN TP20 5432
Coding: FFF7F7FE3B1002
VCID: 70E9A69B6321C1A19FB-8025
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 22
Mileage: 260696 km
Time Indication: 0
Date: 2021.07.04
Time: 13:38:35
Address 23: Brake Booster Labels: None
Part No: 3D0 907 563 F
Component: BREMSBOOSTER 007 0420
Revision: 00007000 Serial number: 00000000011429
Shop #: WSC 00000 000 00000
VCID: 2B5371F78E87E279EA9-807E
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal - MIL ON
Freeze Frame:
Voltage: 14.50 V
Torque: 0.0 Nm
Absolute Pres.: 1.0 bar
Content: 0.0 mm
Current: 0.000 A
Speed: 0.0 km/h
Count: 62
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 J
Component: Klima-Bedienteil D1 0117
VCID: 326D6C93A9ADB3B1A9F-8067
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005521
Shop #: WSC 02891 002 1048576
VCID: 275B8DC7926FC6190E1-8072
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
VCID: 6FEBA5E77A1FDE59861-803A
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 D
Component: Dachmodul 0802
Coding: 0004123
VCID: 24419ACBE3592D012B3-8071
Address 3C: Lane Change Labels: None
Part No SW: 7L6 907 566 B HW: 7L6 907 566 A
Component: J0769_SWA_MasterH10 0070
Revision: 00H10000 Serial number: 6PZ 009 014-01
Coding: 0000152
VCID: 3C7142AB7BE975C1733-8069
Subsystem 1 - Part No: 7L6 907 568 B
Component: J0770_SWA_Slave_H08 0070
Subsystem 2 - Serial number: 6PZ 009 014-21
Subsystem 3 - Serial number: 3F28.05.0800H0800000010157˙
Subsystem 4 - Serial number: 010157˙
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 H
Component: 1X HSG 0201
Coding: 0000040
Shop #: WSC 21377 123 79808
VCID: 3567578F5FC3A4898CD-4B18
Subsystem 1 - Part No: 3D1 959 701 J
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 3D1 959 702 J
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 3D0 959 703 H
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 3D0 959 704 H
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 3D0 909 610 D
Component: 3N HDSG 2430
2 Faults Found:
00485 - Drivers Outside Door Handle Central Locking Button (E369)
007 - Short to Ground
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
Address 47: Sound System
Cannot be reached
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0132
Revision: 00H04000 Serial number:
Coding: 2213953
VCID: 3B7341B77EE772F97A9-806E
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0004
Coding: 00000033
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul r 0004
Coding: 00000033
Address 66: Seat, Rear Labels: None
Part No: 3D0 959 860 CA
Component: Sitzmemory D1 H 1720
Coding: 0000001
VCID: 70E9A69B6721C1A19FB-8025
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 68: Wiper Electr. Labels: Redir Fail!
Part No: 3D1 955 119 B
Component: Front Wiper 3501
Coding: 0013685
Shop #: WSC 01065 000 376832
VCID: 28598EFB9F71C96107B-807D
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 D
Component: 01 Einparkhilfe 0907
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 05:13)--------------------------
The brake pressure sensor problem may be causing the level controller to be unresponsive. The controller 7 may be causing the infotainment issue, have you checked all the fuses. I have no idea which fuse is for the control head.
The brake pressure sensor error was already there and it is related to ACC but everything works. The suspension is also physically in working order, but I can't adjust it with the buttons next to the gearshift. I checked all the fuses. Both those under the steering wheel and those in the luggage compartment above the large battery. I tested the suspension with VCDS and everything works. When I lock the car the suspension also responds and levels it. So it's not about the suspension as such, but about the buttons on the center console.
Discussion Starter · #4 ·
Only I didn't notice if the suspension could not be adjusted with the buttons before or after I started checking all the fuses.
What year is it?
Do you have a ZAB or RNS-810?
Do you have the original bus or the tater bus?
I see the Databus for Infotainment has faults including in the Gateway. Have you tried resetting the gateway?
I also see that a lot of stuff on the Infotainment Bus cannot be reached.
If I was looking for a physical problem, I would check the bus cable and the ZAB or RNS-810.
Discussion Starter · #6 ·
What year is it?
Its 2008 and ZAB how can you reset the getaway? I don't really know how to do it.
That was for the original Gateway. I see you have long coding. I didn't notice that before.
I guess that answers the question about if you have the old bus or the new bus.
You recode the Gateway to the same coding as before. Then the Gateway refreshes the installation list.
See post # 10
(2) Requirement to Refresh the CAN gateway (Controller 19) after Controller Retrofits or Controller Removal | VW Vortex - Volkswagen Forum
If that doesn't help, I would look for a disconnected bus cable or broken bus cable.
I don't know if the newer bus uses all fiber or not.
I worked with Fiber Optics (F/O) in the military. The lines are delicate and you don't want to get the connectors or transceiver lenses dirty. We used isopropyl alcohol or distilled water with special Fiber Optic sponge tip swabs (Q-Tips will leave cotton fibers behind). Since they are so delicate, you can't bend the F/O lines like wires. They will snap inside but look OK from the outside. We had special scopes to see if the connector ends were cracked. We had laser pointers to see if light could make it through the lines. We had to shine the light on a paper or into a test set because it would damage your vision. You can also use a flashlight to see if the line will still conduct light. We had Laser test sets to see if the lines had too much attenuation. We had a whole tool kit including an OTDR (Optical Time Domain Reflectometer).
The old bus only used fiber for the NAV.
If the new bus uses mostly shielded twisted pair copper lines like the old bus, they aren't as delicate but you still have to treat them with care.
Discussion Starter · #8 ·
See post # 10
Many thanks to you. I will try to do that today.
Discussion Starter · #9 ·
Update. In the end, the problem was with the auxiliary heat unit. At the purchase of the car he did not work and the previous owner had disconnected him with the help of coding, but physically the unit was still connected. Unit is just behind the front bumper on the left side over time there was a lot of dirt piling up and it had physically damaged rust, etc. Because AUX heating is connected to A/C, which operates accordingly from the monitor on the central console, it stopped the CAN line and for this reason the music and buttons responsible for suspension hardness and height adjustment do not work. I physically disconnect the AUX heating unit and everything else is now working.
1 - 9 of 9 Posts
