1 - 3 of 3 Posts
Hi there,
No luck in the Jetta III forum, so I'll post here.
I'm trying to replace my front passenger fender on my '95 GL.
I see that there are bolts in the hood gutter that hold it on, but it attaches elsewhere, and I'm not sure how to get it off yet (it is damaged and fairly mangled)
I have a new fender and want to install it.
I guess what I'm looking for is either a scan from the Bentley manual on how to do this, or step by step instructions on the procedure.
Thanks in advance,
Luke
Re: photos or instructions on how to remove 95 GL jetta fender... (volvo_skapunk)
There are I believe 5 or so bolts along the top edge. Remove the metal plate that jumps the fender to the core support on the top edge as well. Remove the inner plastic fender well and against the fire wall you'll find 2 nuts on studs that are sometimes covered up by the gluey stuff used to water seal...
Re: photos or instructions on how to remove 95 GL jetta fender... (Project20v)
ok,
I have all the bolts removed except for the front one.
Now to access it, I have to remove the front bumper, or loosen it enough to drop it out of the way.
heh.. my haynes manual kinda shows how.
so back to the garge I go.
Thanks for the help.
Luke
1 - 3 of 3 Posts
