Re: Pic Request: FK 60/40 on a b3 (vwjetta18t)
Here it is, FK 60/40 Hitec Kit. It is 60mm drop front, 50mm rear
You can't really see them, but there are notches on the rear shock body. I moved the spring perch down 3 notches from the way it came from FK, lowering the back 30mm to a final drop of 50mm. You may notice the side of the spring perch is cut off. I had to do this in order to get some more clearance for the tires, since once I lowered the rear perches they rubbed.
I'm planning on cutting the dead coils out of the rear springs so I can move those perches back up and eliminate the chance of rubbage or the need for spacers.
Modified by BC Dub at 5:51 PM 1-7-2004
