1 - 18 of 18 Posts
Re: Picked up my head yesterday (bajan01)
First of all, Jeremy, you suck.
What's been done to it? And is that a MkIV exhaust manifold I see there?
Re: Picked up my head yesterday (DonL)
Discussion Starter · #4 ·
Quote, originally posted by DonL »
We'll see who sucks when I put that head on
OBDI head
Stage 3 P&P per www.porttuning.com
Decked 0.040"
TT288 cam
Valves with undercut stems (stock diameter valves)
The 0.460" lift on the cam required the head itself to be clearenced
I had both the Mk3 and the Mk4 exhaust manifolds flowed and the Mk4 flowed better so I will use that one. It also weighed a bit less and the ports matched the gasket better so another reason to ditch the Mk3.
Here are a few pics of the exhaust manifold. At the surface it matched almost perfectly but I put the grinder to the inner weld where the real restriction is. I'll have to put a few tack welds on the outside just incase I got too much of the weld. The grinding was a pain in the @$$ but I should be able to handle one runner a day and finish that this week
Exhaust Manifold 1
Exhaust Manifold 2
Exhaust Manifold 3
The lower intake in the picture in the Mk3 that I am port matching and I will stay with that one for now. This intake setup is temporary so it'll do its job for now
Modified by bajan01 at 9:54 PM 2-15-2004
wish i had the money to sent my head out (turning wrenches sucks
) oh well, porting gives me something to do at night, plus i've never actually used any of the heads i ported, so i'm excited to see what this one will do
BTW, how much more did the mk4 exhaust manifold flow than the mk3?
Moderator
Purdy purdy purdy - now get that [email protected] installed.
Re: Picked up my head yesterday (WolfGTI)
Someday this will be me, posting up about my head being done. Then shortly after that I will have it all installed and I will be a happy fat kid. And as always with my luck a dump truck will run over the front of my car leaving me perfectly unscathed to walk over and stare at what used to be my engine, weeping all the way. I washed my car the other day, then I got rear-ended
Good luck with the car Jeremy, let me know if you need anything. http://****************.com/smile/emthup.gif
Discussion Starter · #9 ·
Re: Picked up my head yesterday (bigteal)
Quote, originally posted by bigteal »
Here are the numbers that Jose gave me:
Steel tube exhaust manifold...136.4cfm @ 1.5" of H2O...Weight 8.0lbs (Mk4)
Cast iron exhaust manifold.....125.9cfm @ 1.5" of H2O...Weight 12.0lbs (Mk3)
As I said earlier, the Mk4 matches up very well once the welds are ground down a bit so that's another reason to go with the Mk4
I also celaned up one of the ports on the downpipe tonight which was much easier than the manifold
Downpipe 1
Downpipe 2
The only thing I have to decide on now is where to run my single oxygen sensor as I now have a bung in the manifold as well as the downpipe
Discussion Starter · #11 ·
Re: Picked up my head yesterday (Peanut)
Quote, originally posted by Peanut »
you should have gone with a 16v head sucker.
Too late to turn back now
Re: Picked up my head yesterday (ghettobillgates)
Bajan, I'll be down next week and take a look. You should have it bolted on be then http://****************.com/smile/emthup.gif
Also, 16v's should show no noticeable difference in emissions.
Discussion Starter · #15 ·
Good...I could use somebody to pass me tools
Discussion Starter · #17 ·
Re: Picked up my head yesterday (97GLSsleeper)
Quote, originally posted by 97GLSsleeper »
How much did they charge you to do the work on the head?
A lot...but I bought a crapload of things from Jose so the bill was quite high
He has prices on the webpage...www.porttuning.com. The ABA headwork prices will be similar to the older 8V headwork prices
this is my planned stage 2 engine upgrade for next year
1 - 18 of 18 Posts
