1 - 14 of 14 Posts
Discussion Starter #1
looking for some pics of how they look on mk2's. what have people done as far as the poke they give. i have stock 8v fender flairs on my car and it seems like the fenders should be pulled to reduce some of that poke.
Re: (candyapplebluemk2)
Quote, originally posted by kevinmacd »
Best pics I saw when I bought em http://****************.com/smile/emthup.gif
These are the pro-series but they are 15x8's with a 4.5" backspace I believe
diamond racing wheels? i JUST ordered mine. 15 x 8 with a 4.5 inch backspace will ba an ET of zero, which will need a lot of hacking. 5 inch backspace will be an ET of 12, which will need some cutting also, bit is the most backspace they make.
15x8 RM's, 195/50/15 t1-s, I had to roll the fronts and cut/roll the rears. If you plan on running flairs you can get a bit more aggresive with your clearancing
Re: (Slammed80)
Like I promised, here are some pics of the tires and stuff together
For comparison.....unmounted vs. mounted
Re: (Slammed80)
Quote, originally posted by Slammed80 »
A little off topic, but how low are you, what suspension are you running?
Modified by cabrio_driver at 10:00 PM 7-10-2006
Re: (cabrio_driver)
15x8 et10 all around with 19mm spacers on the rear. The tires are 195/45/15. Also, I am running a VR plus suspension up front.
Modified by seL at 10:23 PM 7-10-2006
Re: (PDXGTI8V 2.0)
Quote, originally posted by PDXGTI8V 2.0 »
wow!!!...scratching the schit outta the face of the wheels by propping them on top of each other and stoopid hammer-on rim wheel weights....remind me to never buy wheels from you, my friend
Yea whoever balanced those needs to find out about stick on wheel weights
1 - 14 of 14 Posts
