1 - 10 of 10 Posts
· Banned
I had the timing belt replaced and i had the timing was retarded well set back to factory zero degree setting.. then it wasn't fast. so i asked shine (shop where i bought the cams) what the proper setting is for the techtonics cams and they assured me it was advanced 6degrees. Now it pings when you accelerate... so i retarded it a lil bit to 4 degrees advanced.... then it wasn't fast.. so i put it back at 6 and it's fast, but how do i cure the freakin' ping?
i run the high test sh*t 93 octance like i'm supposed to.. what else is there..? another adjustment on the cam gear? might that help some?
thanks
Joe
· Banned
Re: Pinging after adjusting timing to proper +6 degrees (Trav)
nah i'm not cheating what happened was i had the non-cam garrett... i've been holding off on the cam chip from garrett kus i'm poor as dirt... i was supposed to have the correct chip last friday but my water pump sh*t the bed on thurs. so that was more important
and yea i did run the car but i don't remember what the hell the results were.. i posted it on that page man go find it http://****************.com/smile/emthup.gif
Re: Pinging after adjusting timing to proper +6 degrees (JoeJetta91)
You might have a bunch of carbon deposits in the cylinder that are causeing hot spots that are pre-igniting and causeing it to ping. You might try running some fuel injection cleaner thru it. Lubro Moly makes some good products similar to this.
· Banned
Discussion Starter · #7 ·
Re: Pinging after adjusting timing to proper +6 degrees (Caleb)
any thoughts on gumout? i have some in the garage i was gonna run it thru anyways just kus i want to... i'll try it tomorrow
thanks
Joe
Haven't tried it but most of that cheap stuff like Gumout and STP is just mineral spirits. I have ran Chevron w/Techron and it worked ok I guess. I used it more as a preventive deal than anything else. Give the Gumout a shot it can't hurt. But you might check out Lubro Moly I have heard nothing but good things about their products and I am sure they have a product that will help if this is indeed the problem.
The crappy winter gas might also be your culprit. I had the same problem in my car w/ the AMS chip and Autotech 270 cam - it would ping like mad under hard acceleration, especially up a hill. I tried Sunoco Ultra 94, and it helped. It's supposedly the best gas you can buy for a street car, although expensive. Try putting in a 1/2 tank, and see what happens. I would take a bet that in the summer, your car would not ping as badly, if at all. Just an idea.
1 - 10 of 10 Posts
