1 - 3 of 3 Posts
Re: plastic screw (CNY_VDUB)
They should just unscrew. It is actually more of a clip, the screw part just expands the clip to hold down the deflector. It is easiest to not apply pressure but rather just lightly turn the screw then pull up on it while still turning it.
If you have to you can just force them out, the threads really suck and rarely work to let the clips decompress enough to come out. I ended up ripping a bunch of mine out and couldn't get them back in. They're pretty cheap at the dealer and I've learned that they have to be oriented the right way to get them to go back in smoothly.
1 - 3 of 3 Posts
