1 - 6 of 6 Posts
i used the expensive version of that and its not as easy as it seems because there are diff plasics out there so to weld it you need the same plastic as the bumper is made from and so on and it does not want to stick sometimes
Re: (tomahawk82)
exactly, I am finishing up a mk3 jetta bumper right now and just used the soldering iron. I started out with the plastic welder but found this to be easy. Once you get the hang of it, it gets easier...good luck http://****************.com/smile/emthup.gif
1 - 6 of 6 Posts
