1 - 16 of 16 Posts
Gots a 2000 GTI GLS 2.0L. As is everyone elses, it is missfireing. Only under 1500 rpm it misses. Stutters bad. Brought it to the dealership and they wont look at it because I have GAIC Chip.
So far I have changed the spark plugs, spark plug wires, Coil Pack, fuel filter, Mass ar flow sensor, and have cleaned the Throttle body and the upper intake manafold. I dont know what else to do. The dealership said it may be dirty injectors. Were and how do I clean the injectors? Please help.
Re: Please help, Dealership Wont even help!!!! (B_TitusJr)
Is it constantly misfiring on one cylinder?
Get a couple bottles of fuel injector cleaner - fill up your tank, dump a bottle in.....run the car. Next fill-up, do the same....fill the tank, dump in a bottle. Has the fuel filter ever been changed?
Quote, originally posted by B_TitusJr »
Re: Please help, Dealership Wont even help!!!! (surferfletch)
I think it's like when my gf talks to me....I appear to be paying attention, but not really...
Re: Please help, Dealership Wont even help!!!! (VW97Jetta)
Quote, originally posted by VW97Jetta »
I've made that an art form with my wife.
Discussion Starter · #7 ·
I use only 94 octane gass. It has a high octane chip in it so I only use that. It misses in CYL 2 constantly. Yes the fuel filter has been changed like a month ago. I think i may change the injectors. I have tried to put that injector cleaner in it and it just dont do it.
Just swap that injector (cyl 2) with another and see if the misfire follows the injector.
Discussion Starter · #9 ·
Re: Please help, Dealership Wont even help!!!! (BlueGTIguy)
Quote, originally posted by BlueGTIguy »
How do I change the injectors?
Are you running an aftermarket cam, and if so, have the valve springs ever been changed?
can't you just swap the stock chip back in and if its still misfireing, bring it to the dealer then???
Re: Please help, Dealership Wont even help!!!! (C7rONi3x)
--careful with that sensible logic, a Global Moderator may dump this thread into the archive.
Discussion Starter · #13 ·
Yes it has a TT 268 cam with a dual spring kit http://****************.com/smile/emthup.gif
Discussion Starter · #14 ·
Quote, originally posted by C7rONi3x »
This is true but I do not have the stock ECU
its probally not the chip dude cause i have the same problem
and i have stock chip, but i can give you advice , fix it now cause i procrastinated now all cylinders are misfiring,it all started with number 2
Discussion Starter · #16 ·
Re: Please help, Dealership Wont even help!!!! (dramalkc)
Quote, originally posted by dramalkc »
Yea It sucks. Did you ever figure out why it is missing
1 - 16 of 16 Posts
