I have an '81 Rabbit that I just had the motor rebuilt on. The motor and trans are still out of the car, and I bolted the motor to the trans to install it. I used a brand new Rhinopac 17-004 200 mm clutch assy, which is the model for an '81, and a 200 mm is what came out of it. The problem is, when you pull up on the clutch arm, you can use one finger to get it all the way to the 10 o'clock position, which is where it should have the pressure plate fully released, and naturally, it's not released at all.
I've had the whole thing apart about 20 times now, and everything is in correctly. The pressure plate is bolted to the motor, the release plate is in with the retaining spring (only one possible way to put that in.) The disc is in with the side stamped "this side faces motor" facing the motor. The flywheel is in with the pins in their slots. The top two, and firewall side bolts are in for the trans to motor attachment. I have a c-clamp holding them together where the starter should be.
I did put the new throwout bearing in, and I did try it with the old throwout bearing in it, still didn't work. The finger that pushes the throwout bearing is not crack, and does bottom out in the slot for the throwout bearing when the arm is in the 10:00 position. I did just try adding the old throwout bearing on top of the new one, and then the pressure plate did disengage and the arm had the proper amount of force needed to pull it up, but I know better than to try to run it rigged like that.
The really crazy thing is that I put a straight edge across the bellhousing and measured to the tip of the release rod when it's at 10:00 on the arm (with only one throwout bearing, of course,) and it would be 1 and 1/8" from the tip of the rod to the back edge of the block. I then stuck a rule in the indentation in the release plate, measured from there to the face of the flywheel, then measured from the face of the flywheel to the block and subtracted the first measurement from the second, the inside of the hole being 1 and 7/8" from the back of the block, which should mean that the rod would be able to push the plate in 3/4". So mathematically, it should work fine.
One last thing, the 5 speed I'm putting in it was the one on the motor when I disassembled it, and it worked fine. I also have the original 4 speed, so I gave that a try, and it's the same situation, no release, and that trans was fine when it came off.
I'm completely stumped, about 10 of my friends are completely stumped, and I'm desperate to finally get this car going, so any help would be greatly appreciated.
Thanks,
Tim
Thanks,
Tim
