Re: Please, someone set the record straight! (Jman5000)
There are also other factors that can throw off dyno results. Such as: outside temperature, humidity, elevation, dyno error. Also all motors aren't built 100% the same, so you could dyno 100 VR6's and get result probably within 5-8 Hp. There are so factors that affect output. Even the type of dyno used can yield results. BTW, 166 at the wheels is pretty good.
Jason
