Poly steering rack bushing?
738 Views 8 Replies 5 Participants Last post by  16v
who has done this retrofit and did you find a noticeable difference?
thanks!
1 - 9 of 9 Posts
Re: Poly steering rack bushing? (16v)
I did this on my '81 Caddy about 5-6 years ago, although was done at the same time as poly suspension bushings, so I can't comment on the difference just from the rack bushings. I do know my old rubber ones fell apart as I removed them.
I ordered them from JC Whitney. My rack was rattling and it most likely can't hurt anything for $10. The only place I wouldn't use poly is where things twist like suspension. It tends to bind a lot sooner than standard rubber and may actually give you less travel due to the binding.
Re: Poly steering rack bushing? (VWCaddy)
quote:[HR][/HR]I did this on my '81 Caddy about 5-6 years ago, although was done at the same time as poly suspension bushings, so I can't comment on the difference just from the rack bushings. I do know my old rubber ones fell apart as I removed them.
[HR][/HR]​
did you feel anything thru the wheel? more 'on spot' wheel to tire direction? When I saw my bushings last week with the car in the air I was astonished that I had any feel for the road..... they are junk
the new bushings are going in tomorrow so I was wondering what to expect
2
Doug,
I put a set of these in the race car, and they made the front end feel 'tighter' on turn-in. I'll be adding some 1/2 spacers to move the rack forward a bit for next year. Gotta make some 'sleeve nuts' though. http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
Re: Poly steering rack bushing? (millerwj)
thanks guys
quote:[HR][/HR]did you feel anything thru the wheel? more 'on spot' wheel to tire direction? When I saw my bushings last week with the car in the air I was astonished that I had any feel for the road..... they are junk
the new bushings are going in tomorrow so I was wondering what to expect[HR][/HR]​
Yes, it was a huge improvement in replacing all the bushings, more solid handling, did not waver in the turns, just held the line you chose. I just can't comment on what the rack bushings alone will do, since I replaced everything at once.
2
quote:[HR][/HR]I'll be adding some 1/2 spacers to move the rack forward a bit for next year. Gotta make some 'sleeve nuts' though. http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif [HR][/HR]​
Why's that??
See less See more
here's the old ones. 17 years:
car has much better on center feel now and even turn in. Good $12 upgrade
See less See more
1 - 9 of 9 Posts
