Looking at doing a 97 - 99 TDI swap into my mk2. What to see some inspiration and some build specs to get my mind going!
Best info i have for you. I recommend doing a 1.9td aaz swap.
http://forums.tdiclub.com/showthread.php?t=142679
an AAZ as all but 4 wires. wheres a tdi has an ecu.
the other big difference is the trans. its an 02A meaning you need to convert to hydraulic clutch and cable shift. versus your original linkage shift and cable clutch.
http://forums.tdiclub.com/showthread.php?t=142679bump for more info.
tuning is all done at the mechanical pump with the AAZSoo pretty much it would feel like a mk4 when driving and I would have to fab up a peddle mount. Wouldn't I want it to have a ecu soo I can do some tuning to it?
AAZ is similar to the stock Mk2 diesels (indirect injection), but bigger.an AAZ as all but 4 wires. wheres a tdi has an ecu.
