1 - 8 of 8 Posts
Have to replace my GTI VR6's (95) pump which is on order. What brand/type of fluid is ok to use. The stuff at the stealership is $$$, saw that Halvoline is compatible is there any others that can be purchased outside of the dealership? Also how much (quantity) to refill the system?
Modified by stiminski at 5:06 AM 2-17-2004
Re: Power Steering Fluid (stiminski)
Make sure the power steering fluid is a mineral oil based fluid.
Adding convential domestic power steering fluid will have the pump fail prematurely.
- Erik
dealer gave me the shop bottle and let me top mine off for free! They only had the big bottle and I only needed a pint or so.
Re: Power Steering Fluid (Skwurlz)
Quote, originally posted by Skwurlz »
Power steering fluid = ATF
No!
Maybe in a Ford or GM, but VW uses a mineral hydraulic oil.
Using ATF will likely damage the system.
Re: Power Steering Fluid (James 93SLC)
Quote, originally posted by James 93SLC »
No!
Yes, it will destroy the pump as noted before.
DO NOT USE AUTOMATIC TRANSMISSION FLUID (ATF) in VW power steeting pumps!
- Erik
Banned
Re: Power Steering Fluid (bluefox280)
bull**** using atf won't hurt the pump, as long as you change it within a few days. I was merely suggesting a simple alternative when your stuck without PSF. I would not recommend this for extended periods of time.
1 - 8 of 8 Posts
