So I've been having power steering issues for awhile now, Originally the power steering wasn't working after parking the car and starting it up again. I've tried disconnecting the battery to reset all the electronics. I did lower my car not too long ago as well. I checked the fuses and the one in the cab for the steering module was sticking out slightly so I pushed it in and thought I had completely fixed the issue. The car was also throwing a 01309 code (No signal/communication to the power steering module) in VCDS. Any who I drive it for a bit, park it, and start it back up again and now I'm noticing the power steering takes about a minute to work after you start up the car. I've already driven the car around to charge the battery as its been sitting for a little bit. Should I try resetting the steering angle sensor? How would one go about doing that? Anything else I should check or try?
