1 - 5 of 5 Posts
my stock 2.0 is ok now but im puting a custom cold air intake on it and in the near future buying an autotech catback exhaust system. What power can i expect to pick up from this? Anyother 2.0'ers have suggestions on how to boost the HP's without forced induction or swaps?
vwhookup.com
Re: Power upgrade (Golfguru17)
Quote, originally posted by Golfguru17 »
The basics. Even though you should have used the search... located at the upper right-hand of the screen (above logout, and to the right of Help) I'm going to tell you some things.
-Intake and exhaust are a "duh".
-Cams, lifters, springs, etc...
-If you want, get a chip dyno-tuned specific to you car.
As for the power gains with your CAI and cat-back, minimal. At most, expect like.. 7-10, but thats a high hope.
if you want to stay N/A, then go to a junkyard, find a mkIV manifold, valve cover, etc, then swap out your intake system for it, longer and larger runners, 1-2 hp. The gains are minimal, but the sound I hear sounds nothing like a dub. I personally would do that, but I am giong FI route, so it would hurt power gains for me. Also, try to get a 276 cam. I hear that the low end has minimal losses while giving you good power output up top (i think around 8-10 hp, but don't quote me on it). Definetly get a chip, either GIAC or TT and get it tuned specifically for your car. Good luck with your project http://****************.com/smile/emthup.gif
1 - 5 of 5 Posts
