1 - 20 of 51 Posts
Wanted to share my build here, any questions on big turboing a TSI or W/M setups feel free to ask. Or if you just would like some info on the build let me know I am happy to help.
Enjoy!
2011 GTI Autobahn CBFA, Candy White.
Mods-
Engine
- Unitronic Big Turbo Software
- Unitronic low pressure fuel pump
- Unitronic high flow fuel injectors
- FFE Racing bottom mount turbo kit
- FFE Racing front mount intercooler w/ Precision 675hp core
- Precision Turbo 5858 ceramic ball bearing vbanded
- Tial MVS wastegate
- Synapse diverter valve 1.25"
- Integrated Engineering Rifle drilled rods w/calico coated bearings
- Farrea +1mm intake valves
- Farrea +1mm exhaust valves
- Farrea springs and retainers
- ER Motorsport Intake
- R8 Coil Packs
- Eurojet Cat and Catback
- Eurojet Catch Can
- Aquamist HFS-4 Water/Methanol Injection. Direct Port, Pre and Post Intercooler
-GReddy B-spec boost control
- BSH pendulum mount
- BFI stage 1 motor and transmission mounts
DRIVETRAIN
- Clutchmasters FX400 6 puck
- Wavetrac Limited Slip Differential
- USP steel shift forks
- Diesel Geek Six Sigma Short Shift
- Verdict Motorsports shift bracket bushings
SUSPENSION
- Eibach Sportline Springs
- Koni Yellow struts and shocks
- Nuespeed Rear Swaybar
- Powerflex control arm bushings
WHEELS/TIRES
- Rotiform 19x8.5 et45 MIA
- Conti Extremecontact 225/35
INTERIOR/EXTERIOR
- OEM Eurolip
- Shaved front end
- Badgeless grill
- LED Tail Lights
- AEM Wideband AFR gauge
- AEM Fuel Pressure gauge
- Aquamist Flow gauge
- Eurojet Boost gauge
- Greddy B-spec
- Rockford Fosgate PBR300.1 amp
- ER Motorsport underfloor sub box w/ MB Quart 10" subwoofer
- USB dummybutton charger
BRAKES
- Porsche Cayanne Brembo 17z 330mm fronts - greenstuff pads
- Porsche Cayanne Brembo 330mm rears
Post 1: Current Setup
Post 2: Previous Setups
The start:
Current Setup
Note this setup has not tuned or dynoed and it is noticabley faster that the second setup that made 489whp.
Helpful info:
Factory Amp Wiring for Sub install
Aquamist HFS-4 Wiring pinouts:
At ECU CBFA MKVI & MKV
Gray main harness:
T90 Connector
- Red Wire (Key Power) pin #3 (red W/ green stripe at ECU)
T60 Connector
- Yellow (FPR) pin #40 (Blue wire at ECU)
- Blue (Map) pin #23 (Green wire at ECU)
- White (Failsafe ECU side) pin #51 (Violet w/white stripe) {possible pin#3 on some models, your #51 or #3 will be empty}
- Brown (Failsafe N75 side) pin #51 (Violet w/white stripe)
Green User Harness (injectors):
T60 Connector
- Red (injector+) Pin #31 (brown w/black stripe)
- Green (injector-) Pin #33 (red w/black stripe)
Board Settings:
CEL - set to DR1
Map - set to 3 bar
Multiplier - set to 2.5x
MKV & MKVI CCTA -
t60
Map sensor is on pin #39 and not #23
WG control is on pin #3 possibly, CBFA wiring diagram showed #3 but it wasn't on an MKVI
:beer: :thumbup: :thumbup:
No, no other weekends away or trips till october. Cranking out some OT while i can $$$
:thumbup: on the turbo kit/build. Different from every other BT build :thumbup:
I'm more interested in the brakes though. What brackets/mounts did you have to get to have the 17Z calipers to fit? I was looking at the 17Z/18Z calipers for the BBK I want to do.
if memory serves me right, the calipers mount to our hubs just fine and you use mercedes suv rotors. all bolts up
Discussion Starter · #10 ·
This 17/18z use a ML350 rotor with a 67 to 65mm hub ring (use metal only), 14mm x 55mm bolts with 5/8" x.035 tubing bushings and last mkiv r32 front brake lines. This will then all bolt ip just make sure your calipers are on the correct sides since they are progressive, little piston is first in the forward direction.
Wow! amazing to get that much power out of 2 liters! :cool: I'd be interested in 1/4 mile times if you ever race it.
Discussion Starter · #13 ·
Nice Ride!!! Love it!
Discussion Starter · #20 ·
Few updates to what been going on since I have not posted in forever. :D
New Transmission is installed and car is mobile again. GLI gtrans gearing is sooooo long, its bout 105ish+ mph in 3rd and 60mph on the highway is at 2k.
Pic of the trans painted before it went in.
Pic of the exhaust manifold and turbo inlet. Also you can see the vacuum pump fitting is spun after the melt down, it does turn without issue. You just need to redo the hoses.
One thing I hated is how the factory heat shielding looked and how it was falling apart, so I changed it to a heat shield that looks factory and works well. Also, added a shield to the bottom of my intake and some of the wiring. Last true shielding was that I wrapped my TB pipe, it looks good too but its almost a shame since the fab work looked amazing.
Added some gold to the hood, it looks good and it will prevent any chance of paint issues from the heat. Attention to detail is everything every edge is siliconed in to make sure no peeling and it looks much better.
Project in the works, teaser ;) (will be done in a few weeks once everything comes in)
Been working on my Daily as well, painted all the clamps and everything that looks bad about this after I took this shot. She has 266,000 miles on her and doesn't burn a drop of oil
Some pics of the bay and overall, almost forgot cleaned up the bay a little and painted the intake as well.
1 - 20 of 51 Posts
