Brakes are the last thing i want to screw with, so i was wondering if or where (toronto) I could buy these pre-made brakelines to install, rather than attempting to make them myself. I assume they cant be that expensive.
Autozone has straight lines you can bend yourself. One type you use with a tubing bender and the other type you can bend with your bare hands (wrap it around something curved in the radius you need it bent to). Just run some string along the line you want to duplicate and measure it out. They have a good assortment of sizes so you should be able to get it pretty close.
make sure you get the bubble flared lines !! here's some info you might find helpful http://volksweb.relitech.com/brakeln.htm http://****************.com/smile/emthup.gif
thanks for that link, its really helpful. I found a place called "frisco autoparts" and im going to contact them tomorrow about all the required parts. Thanks guys.
just did the lines on my mkI and the 5 dollar bender and the bubble flare lines worked great. i didnt have to do the whole thing just rplaces the bad parts of the line. get some compression unions they will help join 2 lines together http://****************.com/smile/emthup.gif
pretty sure compression unions are not legal on brake lines
if u have inspection in your state u might get screwed not to mention they are not as safe~
Not only are they illegal but very dangerous. Brass or copper fittings just cant handle the pressure we heavy footed VW drivers use. The best way to go is to replace the entire line but if that is not up your alley then: cut, deburr, reflare, and use a union to join it to the new line. All necessary hardware can be purchased at a local Parts house.
1 - 12 of 12 Posts
