1 - 1 of 1 Posts
As this entire car has been apart at some point, I need to ensure this rear prop valve is adjusted correctly.
I've poured over the sec 12 of the bent, and do not see this clearly called out in a procedure.
As well, did the searches in the diys..
Suggestions?
presently with the carjacks to chassis, and a two rear jacks one per side, lifting up on the rear axles, to the point the car chassis almost lifts off the jacksstands.. I pulled the spring into place actuating the hydraulic unit to see its range, then left the spring slightly loose then cranked the adjustment bolt.
I realize I'm supposed to have a full tank of gas in this sucker.. hence the slack. Its sitting on coils, not that I really tihnk this sucker is going to move much anyhow..
another issue.
1 - 1 of 1 Posts
