I bought a new truck and NEED TO SELL ASAP! Any reasonable offers will be considered. Original Asking Price -- $5500 -- MAKE AN OFFER!!
A lot of work and effort has been put in to this car. I may have left some things out but you can basically expect to get the following (see below photos for details). If you have any questions or are interested, call Marc at (516)724-4404 or [email protected]
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_1.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_1.jpg" border="0" alt=" photo jetta_1.jpg"/></a>
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_2.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_2.jpg" border="0" alt=" photo jetta_2.jpg"/></a>
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_4.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_4.jpg" border="0" alt=" photo jetta_4.jpg"/></a>
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_3.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_3.jpg" border="0" alt=" photo jetta_3.jpg"/></a>
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_5.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_5.jpg" border="0" alt=" photo jetta_5.jpg"/></a>
<a href="http://s117.photobucket.com/user/sexxy_like_whoa/media/jetta_6.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o79/sexxy_like_whoa/jetta_6.jpg" border="0" alt=" photo jetta_6.jpg"/></a>
4-Door
Power Windows
Power Door Locks
Pioneer head Unit
AM/FM/CD USB Port
Single Sub
Rebuilt 9a bottom end
NEW
Rings bearing and all new seals
NEW
Lifters, valve guides, seals
Head is decked slightly
Port matched
ARP headstubs
ARP con rod studs
AST euro intake cam
Schrick oil pan
VW/MS window tray
New 9a oil pump
50mm pump
50mm intake
cubspeed intake tube
eurosport cool flow intake w/K&N filter
Fuel enricment module
Diesel passenger motor mount, EIP solid front, corrado tranny mount
TT ultra flow stainless cat back xhaust
A/C deleted
New interstate battery, MK3 batterh clamps / new battery (1/13)
Nology hotwire-plugwires
Passat dual fans
Clutchmasters 6 puck clutch disc
Lightened flywheel
Trans:
Completely rebuilt
NEW
Bearings, seals, 1-2 slider, reverse gear
Peliquin LSD with shim kit, pelolock blt kit
MK3 shift weight, TT short shift, all new bushings
VW trans fluid
Suspension:
Weitec 60mm cup kit
OMP front strut-brace
Eurosport rear brace
AST lower control arm brace
AST rear 28mm sway bar
NEW
Control arms, ball joints, poly sway bar links
Bonrath poly upper strut tops
Brakes:
Corrado front 11's
X-drilled brembo rotors with OMP front pads
MK4 rear calipers with new e-brake cables, braied lines
22mm master, ate blue fluid
Exterior:
FK badge-less grill
Crystal clearn quad rounds
Smoked OEM fog lights
Big bumper conversion
G60 flares, front and rear
Euro plate tub
4-Door
Power Windows
Power Door Locks
Pioneer head Unit
AM/FM/CD USB Port
Single Sub
NEW
NEW
Port matched
ARP headstubs
ARP con rod studs
AST euro intake cam
Schrick oil pan
VW/MS window tray
New 9a oil pump
50mm pump
50mm intake
A/C deleted
Passat dual fans
Lightened flywheel
Trans:
Completely rebuilt
NEW
VW trans fluid
Suspension:
Weitec 60mm cup kit
NEW
Brakes:
Corrado front 11's
Exterior:
FK badge-less grill
Euro plate tub
