1 - 2 of 2 Posts
hey people,
i just installed a 3A in my 81 rabbit, i mated a 4K tranny to it, between the two i have a lightened flywheel and a 16V pressure plate, new clutch cable has been installed
problem is i cant get any pedal, the clutch release lever comes almost to end of its travel before engaging plate, i have removed 5th gear housing, removed pushrod, compared it to a new one, is a little worn but cant be the problem, checked throwout bearing, it also is alittle worn, but not enough to be the problem, does anyone know how far the pushrod should stick out the back of the tranny(housing removed), if not any ideas on where to go next?
*** no more problem, turns out i was given the wrong cable, my bad for not comparing it to the old one***
thanks,
mark
[email protected]
[Modified by vdubnvt, 2:15 PM 4-6-2002]
1 - 2 of 2 Posts
