1 - 4 of 4 Posts
I have noticed a very annoying issue on my 2009 CC 6MT.
By design, after removing the key from the ignition, windows can be operated until a door is opened. So far so good.
However, when i remove the key from the ignition while my windows are still closing (auto-up), the driver window goes into reverse and opens all the way, while all other windows continue to close.
This doesn't happen all the time, but it happens often enough to annoy me.
Are there others who have experienced this?
The pinch control is messed up... Press and hold the down button until it completely opens and continue to hold it there for a 5 seconds.. After that pull and hold the down button until it completely closes and continue to hold it there for a 5 seconds..
If that does not fix it you will need to have dealership fix it.
Re: (Boosted2003!)
Quote, originally posted by Boosted2003! »
is this a standard reset of some sort? never heard of this, just curious
thanks
Discussion Starter · #4 ·
Re: (Boosted2003!)
That's the thing I am not sure about, because it happens only when I remove the key while the window is going up
But yeah, computers are humans, too. I'll give the reset thing a try. Thanks!
1 - 4 of 4 Posts
