Re: Problems with 87' 8V GTI HELP!!! (luismr)
sounds like you have the wrong length dipstick. double check the length. it would be sluggish when full because the crank is dipping into the oil and frothing the oil or foaming the oil. this may have caused excessive internal pressure blowing your oil seals out. i'll bet your leaks are at both ends of your crank??
start with the correct dipstick length. http://****************.com/smile/emthup.gif
sean
sean
