Ok my car was up at EPL for about 3 months now.
We had a phantom issue of the car fluctuating what seemed to be boost.
Replaced a bum wastegate that came loose around the oring. Swapped boost controller, fixed stupid little mistakes that happend when several people work on a car they dont know...
The car has peaks and valleys in the graph that fluctuate between 20-50hp.
The boost gauge still vibrates, but doesnt seem to be boost dependant.
The only observational issue i seem to have is the fuel pressure gauge ramps up with boost, flutters then drops way below desireable pressure and the car goes lean.
There are no boost leaks, ive been over every line 20 times, replaced them several times.
The car has these spikes in the graph @ certain rpm points. If i run 13 psi and make 280whp (which is approximate for the boost) it surges at the same rpm as it would @ 24psi which has been around 370whp. You can take a ruler and watch the graph raise up and down rpm per rpm. There are no codes for the cam position sensor, no codes for the incorrect correlation for cam to crank.
we recently thought i was starving the pump with insufficient fueling from the re engineered fuel tank, or we were cavitating the tank with an overload of pressure, so i shoved a screw driver in the filler neck, ran the car. Same problem. Ripped tonys tank out of his green car, with his bosch pump, same problem. Tried different files, different injectors same problem. Different cam position sensors same problem. MBC's same problem. Tried to log throttle position a/f requested vs actual, of course the cable is not holding connectivity.
Any thoughts feel free lol
