1 - 10 of 10 Posts
I have an 02 jetta with a vr6 with 17000 miles on it. When i start the car sometimes it stalls
and almost all the time it hesitates until i give it gas.
What is wrong with it?
thanks
Re: Problems with a VR6? (Chef_Jeff's_VW)
It is probably emissions related. You need to scan the DTC memory.
i had the same problem along with a check engine light.. the dealer replace my cat converter under emissions warranty.
Dang, my VR6 has been excellent. Hang in there. The VR6 has an excellent history of reliability http://****************.com/smile/emthup.gif
Also ask for a loaner. Hey wait your still under warranty. You will be fine.
This too will pass as my mom says http://****************.com/smile/emthup.gif
Modified by loveVR6 at 8:27 AM 2-12-2004
Re: Problems with a VR6? (loveVR6)
could be your maf? or maybe your coilpack? only real answer is take it to the dealer.
Damn quote button is messed up again.
If it is just upon start-up, you might want to look into replacing your coolant sensor with the green-top coolant sensor. I have heard that this remedies some of the cold-start issues. http://****************.com/smile/emthup.gif
1 - 10 of 10 Posts
