I looked around for infos on this conversion and I basically found nothing. Nothing at all.
It's amazing how interchangeable VW parts are. They're like Legos for grown-ups.Yes it is bolt-on for the haldex and subframe with links. The only thing I realised is that the rear track of a jetta is fairly wider that a golf. So I have grabbed rear uprights from a tiguan and they look perfect to match the jetta original track. I still have to take some measurements but I think it should work.
I was expecting the suspension to fit right there, because some guy used mk5 rear irs to install on mk6 jetta to get rid of the rear axle beams.
And equally as expensive as LegosIt's amazing how interchangeable VW parts are. They're like Legos for grown-ups.
Mecanically, I'm replacing pretty much everything but the engine itself, the left halfshaft and the steering rack lol.Can you give us like an overall overview of what your plan is if you get a chance. What parts are you replacing, what are you doing with transmission, fuel pump issues, etc. ?
NNIIIIIICCCEEEE. I wish I knew about this guy before lol. Even the same aluminum subframe at the back.This HAS been kinda done before. there's a guy in Poland who swapped an audi s3 drivetrain into his jetta. 3.2vr6 and all. Projekt Jetta R32 4motion
that being said, i badly want to do this with my GLI
Quick question, but what is that rear subframe out of? Mk5 R32?
As far as I know there were only a limited number of models with the aluminum rear subframes, and one of them (B6 Passat) would cause an issue with your propshaft spacing.
I've found that any of the rear subframes will physically bolt-up (and some will accept different model rear diffs even) to a B6 Passat/CC/Mk5/Mk6 since the subframe mounting points are the same.
However, some of the subframes will place the rear diff more forward and others will place it more to the rear. Just some food for thought.
I also have a spare Mk6 Golf R rear subframe available if you need any measurements from that
I can also get you measurements from my prop shaft if you'd like to see if it would fit, since it is slightly longer than the Mk6 Golf R one. :beer:
Yeah, I had found out about the differential mounting point differences the hard way with my own car. :laugh:Hi Charles,
My rear subframe comes from a euro version R32. I already had the golf r subframe but it was quite rusty so I opted for the aluminum one. On the Passat/Tiguan/CC subframe, the 4 main bolts holes to chassis will fit perfect but the haldex mounting points are different. Especially the front haldex ear that is quite longer and would not fit the PQ35-36 chassis. There is a notch to clear the haldex ear but it's just enough. No chance of clearing the longer version.
The measurements of your driveshaft would be great yes,if you have a chance. Is yours mounted with welded bracket to the body or with the cast mount that bolt under the chassis?
Lol yeah it can be done, but from my point of view, unless you do it yourself, it's gonna be very very very costly.Could you guys do this on mine?
