Well, after putting the front end together on the mock setup, taking detailed measurements and trying to fit my Precision Core under the stock bumper, I have come to the definite conclusion (I think), that my only solution for a good IC is:
1.) AWIC
2.) Build a custom FMIC
Guess which one I am going to undertake :laugh:
My constraints (which did change from the start where I planned on running my Dietrich RS) are now to use the stock bumper, get proper air flow for IC, Condenser, oil cooler and Rad, and look as close to stock as possible. That means to even run the Lower bumper grill as well. I in no way want to hack up a stock bumper and try to stuff a core in there that is wedged to the rebar and blocks all proper air flow.
I did some research on some cores with my measurements and I have a few options. I just need to decide, bite the bullet and build. Bell cores are hella expensive, so I may need to try and set up a reseller account through my brothers shop. Or find a comparable efficient core.
Stay Tuned..
Shawn
