The closest part of the Rad support. I have some better pics I will post up. The Vr support is narrower (allowing more room) between the Condenser and the support itself, but either one would need to be modified. I will mod and reinforce.what would you say was the closest absolute part to the condenser? Enough room for a full IC? Like some Saabs run? Was a model year Passat that ran that setup as well...:
Yea, a factory front mount would be ideal and most are pretty inexpensive brand new, but the problems with the ones that I have searched (2.0t, Saabs, Volvos, etc) is that they are either too tall, or the outlets are positioned to face rear and come in either over the top or sides of the rad and point back. This might work with a narrow radiator (i.e. like the Rallye golf FMIC), but as you know, with FL heat in the summer, a black car and A/C to boot, you need as big of a rad as you can get. So, I am not downsizing that.
What I foresee, is a FM similar in size to the ones you mentioned (large surface area), but the Inlet and Outlet will come off in the same plan as the IC but head out toward the right and left tow hooks. Then pipe around and up as usual.
I have the design already finalized in my mind and it will definitely work nicely. I just need to find and buy the right core to get started.
A 2.5" core looks like it would be perfect, but I could squeeze a 3" core in there if need be. Bell doesn't have a 2.5", but they have a 2.25 and a 3". The Difference in flow is very small (only 25cfm).
No problem. We will get it builtAnd again, Thanks for all the help :beer:
