What part number was it?I just bought a radiator from Hans auto parts (the harbor freight of VW parts). Perfect fit. I'll let you know in a week if it blows up/springs a leak.
Thanks, I just ordered the same thing321121253BL
A turbo diesel with ac.
Total after shipping was $65.
Yeap present, tight, trans shifts properly, clutch works OK, I verified with a borescope the input shaft tp the transaxel is being turned by the motor & not slipping. It appears that the ring & pinion in the differential are no longer in contact. Given what I learned about "Boy Blunder" I suspect the Audi 4000 that provided the engine & trans he put in FrankenWagon had transaxel issues and he did his usual bs repair to it before selling it to the person I bought it from.Hmm. Did the bolt fall out that attaches the lower linkage to the input shaft from the transmission?
