121 - 140 of 151 Posts
Discussion Starter · #123 · (Edited)
Last day in some time with the Jetta.
Halfway there with the calipers.
80635
Driveshafts... really fun to refurbish those! Forgot the outer ones on the rear shaft at home... but still!
80637
80644
80645
80639
Started on my H&R coilovers
80641
80642
80643
80646
Discussion Starter · #124 ·
Also finished both propshaft bearings.
Bought 2 from MK4 and cut off the original brackets and welded on the old ones. Should work out nice!
Need a layer of paint to be finished :)
80647
80649
80651
80652
Discussion Starter · #125 ·
Rear bumper brackets finished welding, just need a layer of primer/paint :D
80655
Front brackets powdercoated on mounted on.
80657
Discussion Starter · #127 · (Edited)
Bois!
Just found out..the front right driveshaft long (hollow) I refurbished is for fwd, and will not fit my VR6 Syncro :/
Mine is approx. 785mm long. I checked with Autodoc, and they said that it fits 2.9 syncro.... but they are wrong...
I am guessing it should be around 585mm long...
But I can't find info about the correct one anywhere!?
please help with the part number?
Etka says 1H0407272AA is the correct part number, but you'll only find ~785mm long driveshafts with that number.
VW CP has a Passat B4 2.9 syncro driveshaft, but I'm not sure if that would fit.
Discussion Starter · #130 ·
Hi!
Thanks for the reply. Yeah 1H0407272AA is the one I have, and it would fit perfect if I didn't have a transfer box.. But its too long.
I see the length of the Passat one is 620 mm, MK2 syncro one is 560mm. 191407272N
Discussion Starter · #131 ·
Got a little package today, from mister Claus Von Essen!
Shore 65 kit for my Jetta. Hope it will bring tighter handling and more racing-like feeling without killing too much comfort :)
Complete engine mount kit, steering rack bushing, crossmember bushing and differential bushing:)
Sent fra min SM-G781B via Tapatalk
Discussion Starter · #134 ·
Tried me an ultrasoundwasher :p
Worked quite well!
83667
83668
83669
Discussion Starter · #136 ·
That’s incredible! Where did you purchase the ultrasound washer?
Right!? :D
We have this cheap retail-franchise here in Scandinavia called "Biltema" (Cartheme). But I guess Amazon/Ebay or similar would have the same quality.
It costed 50$ ish
